F55/F56 LED retrofit headlight
Old Oct 5, 2022 | 06:04 PM
Roman726's Avatar
Roman726
Hopefully this weekend I will be installing this on my F55 halogen headlights.
3” Bi-LED Projectors with Morimoto Bullet shrouds.
Old Oct 8, 2022 | 05:14 PM
Roman726's Avatar
Roman726
Just finished the retrofit, Wasn’t easy but got it done.
Old Oct 8, 2022 | 09:37 PM
mountainhorse's Avatar
mountainhorse
Nice beam pattern... What bulbs and ballasts are you using?
Old Oct 9, 2022 | 07:56 AM
mcbacon89's Avatar
mcbacon89
Very nice! The halogens are actually decent for reflectors but there’s no comparison to a good projector.
This is exactly what I’ve been considering doing, only likely with bixenon vs LED.
How bad were the lenses to get off? I’ve heard they’re permasealed but it looks like you were able to remove them very cleanly.
Old Oct 9, 2022 | 07:58 AM
mcbacon89's Avatar
mcbacon89
If those are bi-LED, then the LEDs are built into the unit. The MLED 2.0 are actually some phenomenal pieces of kit.
I wonder if I can fit a proper koito biled in here….
Old Oct 9, 2022 | 08:20 AM
Roman726's Avatar
Roman726
The LED’s projector came from amazon.
3.0 Inch Bi-LED Projector...
Amazon Amazon
Old Oct 9, 2022 | 08:22 AM
Roman726's Avatar
Roman726
I have to admit they were a pain in the @$$ to remove the clear lens, I used a variety of plastic trim removers and my heat gun. As you can see is doable but not easy at all.
Old Oct 9, 2022 | 10:30 AM
mountainhorse
Sorry.. I missed the LED part of the post...Duh.
Helpful video .... I've used my oven set on 250˚ ... convection seems to work best but not necessary.
Old Oct 9, 2022 | 11:52 AM
Roman726's Avatar
Roman726
This would work if they sealed the headlights with butyl, unfortunately Mini uses permaseal does not turns soft whe heat is applied. I had to use a heat gun and plastic tools to scrape and bend the back of the headlight.
Old Oct 10, 2022 | 11:56 AM
mountainhorse
Good info... thank you.
MINI must have changed from the R56 HL's I opened up.... those had Butyl.
Maybe this stuff could help ??
www.theretrofitsource.com/morimoto-permatrator-solution-for-permaseal-B-PERMA
auguyga
Nov 12, 2022 04:10 PM
NamBot3000
Oct 8, 2022 04:52 PM
synzeus
Electrical
Dec 27, 2019 11:34 AM
umberto
Oct 17, 2017 10:33 AM
HerWanderlust
R60/R61 Stock Problems/Issues
Mar 30, 2016 10:29 AM
