F55/F56 Engine Coolant Help
Old Aug 15, 2020 | 12:10 PM
ranger052's Avatar
ranger052
Engine Coolant Help
Hi all,
I just noticed while replacing the air filter that the Engine Coolant is below the low mark.
Can I just add any coolant or do I have to flush the current one and then re fill? The car has 60K Miles.
Also, How do I flush the current coolant?
Thank you all!
Old Aug 15, 2020 | 06:40 PM
Arrivederci Zagato's Avatar
Arrivederci Zagato
I topped mine off to keep it above the min level 10,000 miles ago without any accompanying steps and had no issue. As far as a complete drain, see this link.
Old Aug 16, 2020 | 05:25 AM
sgscomps's Avatar
sgscomps
Only use the OEM coolant, do not mix it. If your not near a MINI dealer you can also buy from a BMW dealer, it's the same thing just a different bottle. OEM coolant is full strength so you need to dilute 50/50 with distilled water.
Old Aug 16, 2020 | 09:38 AM
ranger052's Avatar
ranger052
Thank you guys!
For my luck I just passed by the dealer and it looks like there is some sort of recall for the EAC Sensor on the radiator and that also involve the coolant and probably why the sensor never gave me a low warning even though the tank is like 3" below the low mark.
My car is OOW but the recall should cover all that.
Lets see how it goes
Old Aug 16, 2020 | 11:13 AM
robby71's Avatar
robby71
just top it up with distilled water for now
Old Aug 16, 2020 | 09:29 PM
Imperial's Avatar
Imperial
Originally Posted by ranger052
Thank you guys!
I have 2016 MCS F55 and when I checked my car for recalls, there were none. What vehicle do you drive?
Old Aug 16, 2020 | 09:36 PM
Arrivederci Zagato
According to a letter in the mail that I received a few days ago, the EAC situation is not a recall. It is a "limited warranty extension" and "not a notice of a recall or service action". This extends the limited warranty of the EAC sensor to 15 years/150,000 miles and affects the following cars:
  • F54, 2016, Prod. Date September 2015- June 2016
  • F55, 2015-2016, Prod. Date August 2014-June 2016
  • F56, 2015-2016, Prod. Date June 2014-June 2016
  • F57, 2016, Prod. Date October 2015-June 2016
Old Aug 16, 2020 | 09:41 PM
Imperial's Avatar
Imperial
Oh, so this is not a recall. It is probably TSB(Technical Service Bulletin). My F55 seems to be within that date, as it was built in May 2016.
Old Aug 18, 2020 | 01:56 PM
ranger052's Avatar
ranger052
So my dealer just called me and all good with the sensor and radiator, they re filled the coolant and good to go.
Michaelh57
R60/R61 Stock Problems/Issues
Apr 27, 2020 04:18 PM
CooperSPT
Feb 26, 2020 02:37 PM
MiniMusician
Feb 16, 2007 01:21 PM
JZBIGZ1
Jul 8, 2004 07:14 AM
