F55/F56 LED Headlight Bulb Swap
Old Apr 14, 2020 | 09:42 PM
Giantsfan107's Avatar
Giantsfan107
I have just installed LED headlight bulbs in my F56 with Halogens. I coded the car via bimmercode to tell the computer that it has LED bulbs in it. This has worked to eliminate flickering, however it still throws high and low beam malfunction codes, which I expected. I also purchased a set of canbus resistors to get rid of the flickering and error codes. However, the resistors still cause the lights to flicker while driving, while they don't flicker without the resistors. The resistors also don't get rid of all of the codes. I am only getting an error for the right high beam malfunction with the resistors installed, vs an error for all 4 when not. My question is, can I just clear the codes and not have to worry about it? Also, is there a way to clear them for free, without having to purchase an app? Thanks in advance!
Old Apr 19, 2020 | 10:15 PM
Giantsfan107
Anyone?
Old Apr 20, 2020 | 06:12 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Cheap LED replacements? Cheap resistors with different values?
Old Apr 20, 2020 | 11:59 AM
Giantsfan107
They weren't expensive, but they had excellent reviews on amazon.
Old Apr 20, 2020 | 12:27 PM
Jstancampiano's Avatar
Jstancampiano
Did you code cold monitoring and warm monitoring to off on low and high beams?
Joe
Old Apr 20, 2020 | 02:45 PM
Giantsfan107
Joe
I did not. Would this prevent the codes from happening?
Old Apr 20, 2020 | 04:43 PM
Jstancampiano
Good chance it will. It's in Bimmercode easy mode for each lamp.
Joe
Old Apr 20, 2020 | 07:53 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The cold monitor checks to make sure the bulb is there during startup, the warm monitor checks the bulb during operation.
pdeinc
Electrical
30
Dec 18, 2020 01:23 PM
Jckol
Jul 12, 2016 08:48 AM
corcorand
Electrical
Mar 2, 2016 05:35 AM
MiniKar
Aug 9, 2012 04:09 AM
