My wife has a 2015 F56, non S, and prefers the look of the S grill. Unfortunately the "S" is molded into the grill. Since there's currently no other option for a replacement grill for the regular F56, I'm looking for possible options to use the S grill. Can anyone with a grill badge see if one could be used to cover the "S"?
Best to do a search for Grille badges Mini Cooper and see what pops up. Get a measurement of the "S" on the grille and buy somethat will will fully cover it.
"standard" magnetic grill badges (available from many sources) are 3 inches in diameter. Most badge holders have a border/rim/lip making them approx 3.5 inches in diameter. OP mentions using a holder that attaches with a velcro strap and IS 3.5 diameter (gobadges.com)
SO question is will a 3.5 inch diameter disk cover the molded in S sufficiently .....
As mentioned in the previous post it will work. I hated the Justa front grill so I swapped it out with the JCW. In order to not look like a big dumb faker I removed the badge and used the above mentioned badge in its place and it worked perfectly. If you get right up on the grill and you know what you are looking for, then yes you can tell, that is splitting hairs.
