F55/F56 JCW Grill on to Non JCW
Old Mar 28, 2018 | 10:52 AM
IamJoe's Avatar
IamJoe
Does anyone know if the the JCW grill will fit on my 2018 F55?
Old Mar 28, 2018 | 10:55 AM
vetsvette's Avatar
vetsvette
Moderator
Yes.
Old Mar 28, 2018 | 02:57 PM
camptown's Avatar
camptown
yes
i have it on my car, which came with JCW badges so I liked the red stripe and added the JCW grill without being too big of a poser. See my pictures in your post about you getting the 2018 Carbon Edition, mine is a 2016 model.
Old Mar 29, 2018 | 07:33 AM
USA-RET's Avatar
USA-RET
Yes...
If you like the red grille stripe, you could have it wrapped. Just make sure you choose a "red" that matches the Chili Red of the JCW should you decide to add more red accents to the car.
I had mine wrapped and it looked fine until I had my brake ducts painted Chili Red through my dealer. Then the grille stripe looked too orange in comparison. Wound up trying to get the cross piece pulled off and painted, but destroyed the grille in the process. So I replaced w/ a JCW grille
Attached Thumbnails JCW Grill on to Non JCW-mini-brake-ducts-no-flash-1-1-.jpg
Old Mar 29, 2018 | 03:37 PM
FunToMini's Avatar
FunToMini
This is something I want to add to my car, but Im curious, are the badges glued on? I do NOT want an S or JCW badge on my car, as it is a base. Also, I dont want people to think its something that it is not; plus I like the badge-less look.
Old Mar 29, 2018 | 03:41 PM
vetsvette's Avatar
vetsvette
Moderator
It's actually molded into the grill.
Old Mar 29, 2018 | 03:42 PM
FunToMini's Avatar
FunToMini
Guess I wont be doing this mod then.
Old Apr 17, 2018 | 04:14 PM
C00per99's Avatar
C00per99
So, it is molded into the grill, but the badge itself can very easily be removed via the threaded nuts on the inside of the grill. I used one of the go badges to cover up the portion of the grill where the badge went (it is slightly recessed and flat as opposed to the rest of the grill texture). It looks great overall and isn't very noticeable at all. It is if you are being very nit-picky about it, but the overall change was way worth it compared to the Justa grill.
Old Apr 18, 2018 | 01:40 PM
Most people have been doing it.
https://www.northamericanmotoring.co...rd-cooper.html
You can see the threaded nut but you will have a little surfboard outline.
kylerogowski
Oct 19, 2013 11:10 AM
IzzyG
Apr 22, 2013 02:29 AM
richardsperry
May 25, 2011 06:29 PM
toolazyforalogin
Jun 30, 2008 07:24 PM
Zooooom
Want to Buy - All Other Items (archive)
Mar 8, 2008 06:25 PM
