F55/F56 Has anyone added F56 rear seat lighting?
Old Dec 31, 2017 | 10:48 AM
chuckee98's Avatar
chuckee98
Has anyone added any type of rear seat lighting to their F56 - footwell, reading, ambient or dome? It's pathetic that there is nothing back there and it's pitch black at night.
Old Dec 31, 2017 | 10:56 AM
punkgeek's Avatar
punkgeek
TIL some people can actually fit in the back of a F56
Old Dec 31, 2017 | 11:09 AM
vetsvette's Avatar
vetsvette
Moderator
I solved that problem by deleting my rear seat.
Old Dec 31, 2017 | 11:27 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
No, but it would be pretty easy to pull the side panels and install some LED's. However when driving at night I would certainly be distracted by light in the back.
Old Jan 1, 2018 | 12:34 PM
TVPostSound's Avatar
TVPostSound
You actually HAD to delete the rear seat, to install a roll bar, cause you needed an anchor for your seat belts!!
Old Jan 1, 2018 | 07:55 PM
vetsvette's Avatar
vetsvette
Moderator
Yeah, well, tomatos, potahtos.
Old Jan 7, 2018 | 04:58 AM
hp79's Avatar
hp79
I think the cleanest way to get it done is to drop the headliner and cut out a hole, wire everything and so on. Lot of work and it might look ugly unless you can find something that would look good. Probably not worth it. there's tons of space between the roof sheet metal and the headliner. I stuffed mine with radiant barrier and it reduced a lot of rain noise and the car feels less cold when it's cold outside.
Old Jan 7, 2018 | 07:18 AM
chuckee98's Avatar
chuckee98
I was thinking of adding some footwell lighting in the side of the rear center console by tapping into the front footwell lighting circuit. My fear is that the F56 uses a footwell module to control the lighting functions in addition to other things (similar to the R56) and that tapping into one of the circuits may cause errors or malfunctions of some sort with the module functions. Gone are the days of just tapping into an simple incandescent dome light circuit and being done with it.
The other thing I can do, which would be less of a risk of errors, is to tap into the 12v power port in the cargo area and mount a reading light in the C pillar. Unfortunately, that would not go on and off with opening a door.
mo168
Feb 24, 2014 03:21 PM
smoke05S
Jul 3, 2012 08:41 AM
jrprich
Electrical
30
Dec 18, 2007 11:19 AM
mini58
Nov 9, 2003 03:54 AM
KPiglet
43
Nov 22, 2002 04:19 AM
