F55/F56 F55/56 Manual Trans Shift Notification
Old Sep 16, 2016 | 02:48 AM
ObiWein's Avatar
ObiWein
Is there a way to disable the gear change notification in the display just behind the wheel?
I've always driven manual cars based on sound, feel, etc. Find the notification to change gears or shift from 1>3 etc. to be rather distracting.
Thanks.
Old Sep 16, 2016 | 04:24 AM
02fanatic's Avatar
02fanatic
I just ignore mine most of the time! Look ahead and "feel" the car....thankfully, a manual transmission still is controlled by the driver!
Old Sep 16, 2016 | 06:51 AM
Nuke-em's Avatar
Nuke-em
Frankly, I forgot it was even there. My first car, a Saturn SC2 had this obnoxious yellow light that would turn on in the instrument cluster.
I'm almost positive there's no selection in any of the menus to turn it off. You would have to do some coding to get rid of it.
Old Sep 16, 2016 | 08:02 AM
ObiWein's Avatar
ObiWein
Originally Posted by Nuke-em
My first car ... had this obnoxious yellow light that would turn on in the instrument cluster.
Me too. Ford Escort. Ugh I hated that light.
This is way less obnoxious, but definitely want to figure out the programming piece to change that to either off or something else. Where should I start to do that and how hard is that likely to be?
Old Sep 16, 2016 | 09:25 AM
Ignoramist's Avatar
Ignoramist
I'm not a fan either.
I do however like the gear indicator because that tells me if I've mixed up 1st and Reverse.
Old Sep 16, 2016 | 01:20 PM
vetsvette's Avatar
vetsvette
Moderator
I'm usually too busy watching where I'm going to look at a gear change suggestion. I seldom look at the tach. It's easier to go by engine sound and feel.
Old Sep 16, 2016 | 03:39 PM
02fanatic's Avatar
02fanatic
Absolutely! ;-)
Old Sep 16, 2016 | 07:27 PM
GDGR's Avatar
GDGR
Those lights/indicators are there for EPA ratings. The EPA testing methodology says that if the car has an indicator that says when to shift, then the tester has to follow them. That's how they get good fuel economy on the window sticker. Without such an indicator, it's likely the car would have 1mpg lower on the sticker. And per the same rules, the indicator must not be able to be disabled.
Old Sep 18, 2016 | 03:14 PM
bratling's Avatar
bratling
Super Moderator
My dad had an SL2 that I learned stick on. As a learner I found it very reassuring to have the guidance. It was also decently programmed; rather than triggering at a set RPM it was throttle dependent. If throttle was wide open, it delayed the light to much higher in the curve.
Some parts of the car aren't there for the experienced drivers.
Old Sep 19, 2016 | 07:41 AM
ObiWein's Avatar
ObiWein
Gotcha. I can live with that logic then.
Already started to ignore it.
Old Sep 19, 2016 | 01:05 PM
Dan-FL's Avatar
Dan-FL
Try a piece of tape over the indicator :-)
deanjohnson
Tires, Wheels, & Brakes
Nov 25, 2019 08:10 PM
Refinisher
Dec 20, 2016 05:57 AM
DRMCDAVE
Sep 6, 2016 04:55 AM
HavocVsChaos
Aug 30, 2016 05:59 PM
Mini_Chan
Aug 29, 2016 07:40 AM
