F55/F56 F56 OBD Reader recommendation?
I have a 2014 F56 and the check engine light is on. I'm out of warranty and an hour away from the dealer. I'm considering purchasing my own OBD reader. I don't know anything about them.
Does anyone have one they recommend?
I have an HTC android phone is that is an option.
Is there anything special about a MINI reader?
I know I can go to an auto parts store and borrow one from them.
Thanks, this has a selection for the F56. Ours has the regular OBD2 reader and then MINI specific code reader ( as well as BMW and Rolls Royce )
https://www.northamericanmotoring.co...d-q-and-a.html
i first went with a knock-off elm327 reader off amazon. while the truth is that it worked (and still does work) 100% perfect, the issue i had was that it was bulky. that caused issues in that i would kick it off often and when i was racing @ the track, my instructor got really annoyed when it was knocked off mid-turn.
i ended up going with the OBDLINK LX for a few reasons
- every app/product that requires bluetooth reading always recommends using the OBDLINK LX
- size: it's freaking small and fit a lot more snug. the above issues went away with that.
for $50, you get the unit and 2 apps. i use the first one (OBDLINK) a lot. i use it to read diagnostics, reset codes, treat is as a dashboard (oil/water temp, boost, STFT, LTFT, etc...). and the most important reason for me having it. it will tell me when my car is "ready" for emissions testing (aka if you test now, you'll pass). i have a downpipe so for me, knowing that my car is reading as all healthy is a huge plus for me. truth is, the readiness kicks in after 100 miles of driving w/out doing an ecu-reset. but it's good to know that i can click it and it will say ready or not ready, then i go do inspection.
or if you don't want to spend a freaking dime, go to autozone and they'll do a free reading.
what does "knock-off elm327" mean? Do you think the chips are fake?
I have an odblink LX too, and I have found it unreliable but the good thing is you can hard-reset it with the green button
bad news is I've never had to do that with my other odb readers, go with amazon reviews, veepeek has a highly reviewed very low profile one
unreliable, or claim to be the latest chipset but are a VERY old version.
if it has great reviews, then by all means go for it. i'm surprised you've had issues with your obdlink lx...i've never had a problem with mine. luck of the draw i guess. i use it to track my data when i track the car and have not had a hiccup yet. maybe sometimes it won't see it, and i'll either reboot my phone or unplug/replug the obd unit...but otherwise that's it.
Thanks for the feedback. I ordered an OBDlink LX via Amazon for $50 plus tax. I'm looking forward to playing with it.
Oh, I remembered the dealer told me after an oil change a month ago my spark plugs would need replacing soon. That is probably what the code is. They want $191 to replace 3 spark plugs! Yikes! I thought about doing it myself, but the plugs are $24 each and you need a $50 tool to get at them. I'll find someone local to do it and let them learn about my MINI.
I'm at 80K miles in just over 2 years. I drive a lot. But it does seem a little soon if bad plugs is what is causing the cel.
Also, has anyone been able to use a OBD II scanner to find out more specifics on "Drivetrain Malfunction" error message?
My F56S (60K miles) has been intermittently showing this error message lately, both time just coming out of a parking lot at about 10-20 mph with moderate to slow acceleration. But the car drove fine.
I got home and turned off the engine and hooked up a generic hand-held OBD II code reader. And turned on the engine again but the error message was gone on the dash. And there code reader says there is no stored code. ???
Been a while and I was wondering how this device has been working out so far?
2) are you running a jb4 or nm? IMO, a drivetrain malfunction is the car not happy with a reading it saw. in other words, something did not fall within the expected range (making numbers up, it expects a value between 0-10 and it receives 12.5...car says wtf that's impossible).
3) i had numerous drivetrain malfunctions that were resolved with a software upgrade from mini. note: my car is a february 2014 build, so it's probably part of the first batch that left the factory. my software was updated last year.
hope some of this helps you.
Thanks for the quick response!
> Was your OBDLINK LX able to give you any specifics about the Drivetrain Malfunction error message? Like too lean, misfiring, etc?
> My F56S is 100% bone stock other than tinted windows. Never raced and religiously maintained. It's just a everyday commute car about 60 miles a day.
> I bought my Mini in 2014 July and never had the software update done. Does dealer charge for the software update after warranty period is over?
good luck.
Other brand cars have a "Check Engine Light" when an engine parameter is amiss. But Mini has both "Drivetrain Malfunction" light and Check Engine Light (the latter I haven't seen on my Mini yet). I'm guessing that Drivetrain Malfunction light includes engine, transmission error & software error, and Check Engine Light deals with more serious engine related issues only.
Can someone explain more in detail the difference between the two?
Also, when the Drivetrain Malfunction light is on, would it be able to pass the required state smog check?
Mine is not due yet but just wondering.
but exactly the same happened to me (check engine light) and I am having an F56 JCW January 2024 model.
I've tried two obd readers that I had (konwey and ELM ) but they do not work,and I am somehow lost between the options versus what will work. I do not know what to buy.
if possible, some help please?
Apologies for the outdated posting,
(1) Bimmerlink app (runs on your phone)
(2) Wireless OBD-II adapter that will talk to Bimmerlink. There is a list of compatibles. Cheapest I've seen, and it does the job (I bought one) is the Veepeak OBDCheck BLE (communicates with your phone via Bluetooth).
Bimmerlink is not a full-fledged professional do-all-the-things scanner. But it will absolutely let you read BMW/MINI-specific codes.
PelicanParts.com
Mar 24, 2016 09:27 AM
PelicanParts.com
Mar 22, 2016 08:44 AM
ByeByeFJ40
Jul 18, 2002 10:04 PM
