F55/F56 Oil change before 1,000mi
Old Mar 3, 2016 | 05:38 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
So Im 200mi from my 1000mi break in window (FINALLY!!), I was going to get my oil changed to get rid of the break-in oil because it just works out for me instead of getting it next week.
Any thoughts if I should keep the break-in oil in until next week?
Thanks in Advance
Old Mar 3, 2016 | 06:08 PM
KazO's Avatar
KazO
Does a week make a difference? I did mine at 1500, and given the admittedly small bits that were in it, I'd recommend it. Also, I doubt it has actual 'break-in' oil like M cars did a decade ago (AFAIK ///Ms don't even have that anymore).
Old Mar 3, 2016 | 06:18 PM
jrodri7's Avatar
jrodri7
Thanks in Advance
I thought break-in period was 1,200 miles?
I replaced my oil at 1200 last week when it went in for the bearing TSB
Old Mar 3, 2016 | 06:20 PM
Mini_Vinnie
Moderator
True but I've always changed factory oil when I got out of the breakin window.
I've read a lot of the little pieces you mentioned so that is why I really wanted to get the oil out. You are probably right, 2-3 days wont matter.
I'm just excited to be able to get over 4K rpm in a few days
Old Mar 3, 2016 | 06:21 PM
Mini_Vinnie
Moderator
Originally Posted by jrodri7
I thought break-in period was 1,200 miles? I replaced my oil at 1200 last week when it went in for the bearing TSB
Mine says 1000-1200 mi
I think.
jrodri7's Avatar
jrodri7
Old Mar 3, 2016 | 07:23 PM
Mini_Vinnie
Moderator
Ok great I just looked in my manual and say that thanks.
I emailed my salesman because I could have sworn he said 1000. Im sticking with the book for sure though.
Old Mar 4, 2016 | 01:58 PM
Lucila's Avatar
Lucila
I purchased my mini off the lot at the end of November. My computer says my first service is due in May ( the month it was built). I went ahead and booked an appointment on Monday for my break-in oil change. I currently have 3200k miles. I can count on one hand the amount of times I drove it hard. Did I wait too long???
Old Mar 4, 2016 | 07:05 PM
pppdxx's Avatar
pppdxx
In my opinion 1000 miles is way too long. I recommend servicing your oil every 725 miles.
Old Mar 4, 2016 | 08:00 PM
pjsjr13's Avatar
pjsjr13
What do you attribute servicing oil every 725 miles?
Old Mar 4, 2016 | 09:12 PM
Lucila's Avatar
Lucila
+1
Old Mar 5, 2016 | 03:33 AM
vetsvette's Avatar
vetsvette
Moderator
It's a PITA thing. I plan to make the first change on my new engine between 1K and 1.2K miles... whichever is convenient. By then it should have created or shed the majority of the wear and tear bits and debris from break in.
Old Mar 5, 2016 | 05:08 AM
02fanatic's Avatar
02fanatic
Me too!.....I'm at 552 or so miles & when I get close to 1,000 miles as I drive more this spring I'll be making an appointment with my MINI Dealer for an oil & filter change...1st maintenance check since new.
My local Independent BMW mechanic will be changing the oil & performing inspections some of the time but I will use the Dealer the first oil service & for warranty work. I will be wanting to know which oil & filter they use as well.
By the way, is there a reset procedure for the oil service indicator on the dash...Similar to BMW's? I have a Peake Reset Tool for my Bimmers. I might want to get the reset tool since I might be changing my own oil at some point too (having a lift, that makes total sense)....just need to learn more about this JCW!
Btw, vetsvette, I'm happy for you with the new engine. That's a bummer needing a replacement on a new MINI. Good luck with it!
Cheers,
John
Old Mar 5, 2016 | 05:58 AM
vetsvette's Avatar
vetsvette
Moderator
Not sure about the reset. I'm not messing with mine until after my warranty runs out (9/2019 or 75K miles). I'll still let them do it until I have 36K on it and I will make sure I document all changes until 75K. I'll do my own in between dealer mandated changes. I have a local guy that does all my oil changes for me on all my vehicles. I buy Mobil 1 at WW for $24 and in the Mini's case a factory filter and he charges me $12 labor. It's not worth jacking it up or driving to my Buddy's house to use his lift for that price.
Old Mar 5, 2016 | 06:06 AM
goin2drt's Avatar
goin2drt
I changed it at 1,200. The oil that came out was actually really clean. All the hype of bad oil, break in oil etc etc is a bit overrated IMO. I still do it on all my new cars but it isn't the 70's any longer.
Old Mar 5, 2016 | 06:51 AM
pjsjr13's Avatar
pjsjr13
Cheers,
John
To my understanding the oil reset is completed using the secondary menu with the reset stalk that comes out of the speedometer.
Old Mar 5, 2016 | 07:08 AM
02fanatic's Avatar
02fanatic
Thanks Peter!
Old Mar 6, 2016 | 05:14 AM
Mini_Vinnie
Moderator
I ended up getting mine changed at 927mi and I was able to watch the tech do it. He used a little screen to catch the oil and there were some metal pieces in the oil, not a lot, normal amount for a break-in period (techs words) so I was glad to get it changed.
Old Mar 6, 2016 | 03:25 PM
Blues Trucker's Avatar
Blues Trucker
Over 4000 miles and nobody ever said squat about changing oil till 10,000 miles.
What are ya all talking about.
Old Mar 6, 2016 | 04:42 PM
Mini_Vinnie
Moderator
I guess Im old school or gullible but I cant wrap my head around going more than 5k miles without changing oil. 10K just doesnt seem right.
Old Mar 6, 2016 | 07:32 PM
dpcompt's Avatar
dpcompt
Oil intervals
10,000 mile oil changes are nothing new. Porsche has been using synthetic oils for years and have had 10,000 miles oil change intervals since the late '70's. With these modern oils, you're wasting your money changing oil more often than 10,000 miles.
Old Mar 6, 2016 | 07:39 PM
vetsvette's Avatar
vetsvette
Moderator
You are correct. My car, my money, my time, and my peace of mind.
Old Mar 7, 2016 | 04:59 AM
gjxj's Avatar
gjxj
Worth a note changing the "break in " oil is not a reccomended service item. Don't expect it to be done free under your maintenance plan, and don't blame your dealer for not saying anything.
Old Mar 7, 2016 | 08:10 AM
Mini_Vinnie
Moderator
I went to an Indy garage and it was $85.
Old Mar 7, 2016 | 09:01 AM
vetsvette's Avatar
vetsvette
Moderator
I supply oil and filter and labor cost is $12 at my shop.
5 Quart jug Mobil 1 at WW- $24.00
rebate from Mobil 1 - $12.00
OEM filter - $8.00
Labor - $12.00
Total cost OTD - $32.00 = cheap insurance and peace of mind.
