F55/F56 oil change
Old Feb 27, 2016 | 06:08 PM
Martys's Avatar
Martys
oil change
hello, I purchased my F55 a couple of months ago and now have 3000 miles. How often do you change the oil/filter.
thanks
MartyS
Old Feb 27, 2016 | 06:59 PM
whaap's Avatar
whaap
I'm old school. First oil change with a brand new car around 1-3,000 miles. The rest every 5,000. Everyone has their own opinion on this and seldom are two the same.
Old Feb 27, 2016 | 08:00 PM
vetsvette's Avatar
vetsvette
Moderator
^^^ What he said ^^^
Old Feb 28, 2016 | 10:51 AM
miata1's Avatar
miata1
I agree.
Old Feb 28, 2016 | 11:43 AM
Fly'n Brick's Avatar
Fly'n Brick
+1
Oil and filters - cheap
worn rings and bearings ???
Old Feb 28, 2016 | 11:48 AM
pppdxx's Avatar
pppdxx
I'm gonna go against the grain here and change my oil when the CBS tells me to. I'll let you know when my engine blows up.
Old Feb 28, 2016 | 12:03 PM
elvis cole's Avatar
elvis cole
pppdxx must have clean hands and deep pockets. It will be only a few years until he tells us the news.
Old Feb 28, 2016 | 12:25 PM
goin2drt's Avatar
goin2drt
At 1,000 and then every 5k intervals.
Old Feb 28, 2016 | 12:38 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
The longer you want to keep the car the shorter the oil change interval should be. Mini turbo 5000 or less! Go find someone who goes by the mini interval and check out what the oil looks like at 10k. They might think you are weird for wanting to look that is the only downside.
Old Feb 29, 2016 | 10:53 AM
5,000-7,500. You will be fine. I am at 260K on my 05' MCC.
Oil change kits Here w/ DIY in the future , theer are 2 main kits one for the Cooper ( 1.5L) and one for the Cooper S / JCW ( 2.0)
https://www.northamericanmotoring.co...rocedures.html
Old Mar 2, 2016 | 04:21 PM
fradaj's Avatar
fradaj
9K miles or 1 year is what MINI recommends.
Old Mar 2, 2016 | 07:26 PM
vetsvette's Avatar
vetsvette
Moderator
Yeah, they started out recommending 15K on the R56 too. Look what that got them.
Old Mar 2, 2016 | 11:11 PM
BadakVT's Avatar
BadakVT
I agree with Vetsvette.
Here in S.E. Asia, where 90% of driving is start/stop traffic, short distance trip, and bad gasoline quality, the official mini interval is 8000km/5000 miles. Which means Mini/BMW is aware that a universal 15K miles interval might cause problems. Hence they now have different interval for different regions in the world, depending on the severity of the usage, climate, etc.
So if Mini USA recommends 9-10K miles, I would change the oil every 5K miles which is right in the middle of the free oil service.
If I'm not mistaken, the new BMW/Mini oil is Shell/Penzoill Platinum PurePlus with the new GTL base (Group 3), which is a good oil. Should be plenty of TBN cushion for 5000-7500 miles interval. But again, why not do your own oil change in the middle of the free service just to be on the safe side.
Old Mar 3, 2016 | 04:25 AM
Martys's Avatar
Martys
oil change
based on all of the recommendations got the oil changed at 2750 miles. Best $75 spent on the car,
MartyS
Old Mar 3, 2016 | 05:33 AM
Yep the new Oil is shell Euro , the gas to oil production type.
Old Mar 3, 2016 | 06:14 AM
vetsvette's Avatar
vetsvette
Moderator
Am I correct in assuming that Mobil 1 0W40 is good for the F series also? I have a half dozen 5 quart jugs that I plan to use in mine eventually.
Old Mar 3, 2016 | 06:40 AM
Yes the Euro formula stuff will be fine. Meets LL-01
Old Mar 3, 2016 | 09:25 PM
Conrad_Thomaier's Avatar
Conrad_Thomaier
You're getting a lot of recommendations to change the oil/filter more often than MINI recommends. The recommendation is based upon what their dads did in the 1960s. No one has offered any proof that the shorter oil/filter change recommendations are necessary.
If anyone has had their oil analyzed to support your recommended oil/filter change intervals, please publish.
I'm at 64k on my 2014 F56 and have had the oil changed when the service light comes on, about every 12k miles.
Old Mar 3, 2016 | 10:18 PM
Minnie.the.Moocher
Recommendation is based upon visual inspection of oil from a turbocharged engine after 8K miles in my car. And having to replace gummed up Vanos solenoids. Mostly long highway drives and the longer intervals are probably better, but a lot of local short stop driving like I do results in sludge. Mini had higher intervals on the older engines and then had to back them down because of many issues.
Old Mar 4, 2016 | 05:08 AM
vetsvette's Avatar
vetsvette
Moderator
Thanks. I couldn't find anything F series specific.
I just got my car back with a new motor. Oil Will be changed after 1K miles of break-in, and changed every 5K after that. The technician/mechanic that swapped my engines said he does the same thing. Even though Mini USA frowns on them saying that. As far as I'm concerned, the 10K figure just means they only have to supply three "free" oil changes for a new car. My '07 R56 went 130K before I traded it in. Oil was changed every 5K.... not counting the quart that was added between oil changes.
Old Mar 4, 2016 | 05:49 AM
Welcome.
ToThePublic
Mar 8, 2016 06:59 AM
jpwins
11
Feb 26, 2016 12:16 PM
PelicanParts.com
Feb 25, 2016 09:21 AM
PelicanParts.com
Feb 24, 2016 08:51 AM
chili04
Feb 18, 2016 08:30 PM
