F55/F56 Anyone have these?
Old Dec 31, 2015 | 12:07 PM
DAVIDLEERAD's Avatar
DAVIDLEERAD
Anyone have these?
Thinking about getting them for my 2015 MCS. If you do have them, do you like them? Thanks for any input.
Old Dec 31, 2015 | 12:15 PM
Those are new ( 63122361243 ) and follow the same system as the R56 -R61 DRL , but in F56/ F55 version. very popular for the Gen 2 MINI version. Super bright and the DRL ring seems brighter ( more blue / purple) in the retrofit kit them the factory ordered LED kit.
Seem them on a MINI promo car,
https://www.ecstuning.com/Search/SiteSearch/63122361243/
Old Dec 31, 2015 | 12:24 PM
DAVIDLEERAD
MINI COOPER F56 Spot Lights & LED DRLs - Studio Reesau - YouTube
Thanks for the reply and for the video.
I have the LED headlights.... will they cancel out the DRL Omega rings or will I have 2 sets of DRLs? Thanks again
Old Dec 31, 2015 | 12:36 PM
Welcome,
These are for cars without LED headlights / led fogs, hence there in the halogen headlights car.
http://www.realoem.com/bmw/enUS/show...91#63122361243
It would take coding for them to work with the factory LED DRL Fogs, plus it would take the place of the the factory fog leds that you have. No one i know has done this yet to mod it.
Old Dec 31, 2015 | 01:01 PM
DAVIDLEERAD
Welcome,
Hmm, I'll have to ask the dealer.... It would look great to have the headlight DRLs and the fog DRLs at the same time.
Old Dec 31, 2015 | 01:12 PM
Dealer might not know either as this is so new. Also the drl code SA520 will be on so with this kit the code will have to feed the Omega lights also. Good luck, thats what i have so far.
Old May 8, 2016 | 11:30 AM
BeerChan's Avatar
BeerChan
Anyone have access to the installation instructions for the new Gen3 LED DRL? I bought a set, but of course, no instructions. It should be an easy install, but there is a bit of wiring to be done to the existing connectors, so the instructions would be a great help.
Old Jun 23, 2016 | 07:11 AM
BeerChan's Avatar
BeerChan
I finally got around to doing the install of these and they look great! I did manage to get the installation instructions from the dealer, though you really don't need them. The procedure is simply disconnect all the wires from the existing lamps through the access hole, then remove the front bumper, which is easy. Then pop the old lamps out and put the new ones in, cut off all the old connectors and butt join like colored wires on the new connectors to the old wires, each is a different color/stripe. The kit does provide heat shrink tubing to go over the butt joins, but beware, the tubing is thick and requires a proper shop heat gun, a hair dryer doesn't do a good job on these. If that is all you have, you may want to get some thinner tubing at the hardware store.
Also, contrary to what some retailers have on their websites, there is coding involved. You have to disable the bulb checks or else you will get check codes.
Using ESYS, I coded the Daytime running lights, fog lights and parking lights to LED, and turned off the cold and warm bulb checks.
In the BDC Module, section 3060:
Daytime Running Lights
TFL_L_KALTUEBERWACHUNG - change to nicht_aktiv
TFL_L_WARMUEBERWACHUNG - change to nicht_aktiv
TFL_L_IS_LED - change to aktiv
TFL_R_KALTUEBERWACHUNG - change to nicht_aktiv
TFL_R_WARMUEBERWACHUNG - change to nicht_aktiv
TFL_R_IS_LED - change to aktiv
Front Fog Lights
NSW_L_KALTUEBERWACHUNG - change to nicht_aktiv
NSW_L_WARMUEBERWACHUNG - change to nicht_aktiv
NSW_L_IS_LED - change to aktiv
NSW_R_KALTUEBERWACHUNG - change to nicht_aktiv
NSW_R_WARMUEBERWACHUNG - change to nicht_aktiv
NSW_R_IS_LED - change to aktiv
Parking lights
POL_L_KALTUEBERWACHUNG - change to nicht_aktiv
POL_L_WARMUEBERWACHUNG - change to nicht_aktiv
POL_L_IS_LED - change to aktiv
POL_R_KALTUEBERWACHUNG - change to nicht_aktiv
POL_R_WARMUEBERWACHUNG - change to nicht_aktiv
POL_R_IS_LED - change to aktiv
I while I was in there, I also coded the fogs to stay on with the high beams
NSW_AUS_BEI_FL - change to nicht_aktiv
Also of note, if you do the coding while you have a bulb check warning, the warning will not be cleared, since the checks have now been turned off so there is nothing to change it. It will be reset once the ECU goes to sleep, so just leave the car off for a while.
Old Jul 18, 2019 | 11:30 AM
https://www.northamericanmotoring.co...nt-bumper.html
Install PDF linked here ^^^
Old Oct 1, 2019 | 09:05 AM
The Snowman's Avatar
The Snowman
I have a 2019 F56 w/ the factory halo/LED headlights. I also fo not have factory fog lights. So, 2 questions:
1) Will these work on my model?
2) What would be required in order to utilize the fog light feature of these?
Old Oct 1, 2019 | 10:52 AM
The Snowman
I noted the following in the description:
* For MINIs without LED headlight / LED Foglights
What would happen if I did install these with the halo/LED headlights?
Old Oct 1, 2019 | 10:54 AM
I dont know if they would work as it pulls drl function. You could give it a shot then try to work around it. I dont know anyone that has tested it with LED headlights. Thats just what MINI states.
Old Oct 1, 2019 | 11:27 AM
The Snowman
It'd be a pretty expansive gamble.
All I'm really looking for is an OEM set of fog lights. But Mini's site doesn't list them.
Does any of the 2019 Mini's come with the halo/LED lighting and fog lights? Or is it one or the other? I just like the look of having fog lights on w/ the headlights.
Old Oct 1, 2019 | 12:10 PM
Only ones we have are these for retrofit to LED fogs/ DRL in place of original halogen fog light option: They are an OEM style.
https://www.ecstuning.com/b-vinstar-.../v-130116~vin/
Pauley04
Jul 9, 2020 11:24 PM
muellerfilm
Feb 17, 2018 02:03 PM
NYC Eng
Electrical
38
Oct 19, 2016 06:40 PM
Giano
Sep 24, 2015 07:16 AM
renchjeep
Jul 16, 2014 11:49 AM
