F55/F56 Hatch Struts
Old Feb 9, 2015 | 05:44 AM
torpeau's Avatar
torpeau
Hatch Struts
I leave my hatch open a lot because I am constantly putting stuff in there to be recycled. (Also, it prevents me from seeing the poor fit of the hatch.)
Anyway, the struts no longer keep the hatch open. If I leave it up, 5-10 minutes later it fall shut. Anyone else have the problem?
Old Feb 9, 2015 | 07:38 AM
Nuke-em's Avatar
Nuke-em
I've never experienced this particular problem. However, it does seem that the hatch closes rather forcefully if you let it close on momentum. I've made it a habit to pull the hatch down most of the way and then let it shut via gravity.
I thought the struts were undersized for the application; apparently there may be some substance behind my theory.
Old Feb 9, 2015 | 08:14 AM
talasyn's Avatar
talasyn
This is my chief complaint about my F56. The hatch crashes down. I'm waiting for my back window to shatter at some point. Its "ok" when I close it, as I'm aware of the issue, but when someone else closes the hatch, I'm just waiting for the glass to fly. Any suggestions for aftermarket items?
Old Feb 9, 2015 | 08:18 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Amazon.com: Qty (2) MINI Cooper 2002 To 2014 Hatch, Liftgate Lift Supports, Struts (Exc Split Door): Automotive Amazon.com: Qty (2) MINI Cooper 2002 To 2014 Hatch, Liftgate Lift Supports, Struts (Exc Split Door): Automotive
I've used products from this company on another car. American made, easy install and worked better than OEM. No experience on the mini product however.
Old Feb 9, 2015 | 10:03 AM
hp79's Avatar
hp79
I actually like it being this way. My 2014 Mazda CX-5 trunk has to be slammed to close properly, sometimes even twice. With my 2015 F56 trunk, I can just let go of the lid from 6 inches from closing position. The first time I closed the trunk, I too thought the glass was going to shatter. lol.
Old Feb 9, 2015 | 11:02 AM
torpeau's Avatar
torpeau
Got a lump on the back this morning because the hatch crashed down on me w/in 5 or 6 seconds as I was removing stuff to be recycled. A BIG lump! Will have to use a broomstick to prop the damned thing up whenever I unload. I'm sure the dealer will do something about it when it's convenient to go there.
We also have a 2014 CX-5 and I don't really have to slam that hatch. I don't like the iPod problems the CX-5 has, but otherwise a tight, well made vehicle.
Old Feb 9, 2015 | 11:41 AM
hp79's Avatar
hp79
Eww.. that sucks. I guess you should get it fixed.
I sometimes keep the trunk open too just to air out the interior. I only started doing this after I replaced the trunk light bulb to a LED one as the standard light bulb gets pretty hot in there and uses a lot of power too (8 Watt) as it will be lit up for 15 minutes.
Yeah, the infotainment system on the $30k CX-5 is POS. I didn't get the tech package, but it still sucks taking so much time every time it syncs the address book, and playing USB music from track 1 every time. Otherwise a solid compact SUV. I'm happy with the base radio on the F56, at least the phone works flawless, and music plays where I left off.
Old Feb 9, 2015 | 11:59 AM
torpeau's Avatar
torpeau
Up until now, letting my F56 air out inside has been another reason to leave the hatch up. Never have worried about that light staying on for that 15 minutes.
Regarding the Mazda, the Mazda forum has a very long thread on the problems working w/ the iPod in the CX-5 and also the Mazda6 -- even the '15s. My iPod works great w/ my MCS and also worked great w/ my '10 VW CC.
Old Feb 9, 2015 | 01:10 PM
Nuke-em's Avatar
Nuke-em
Have you guys thought about laying off the beans for a while?
Old Feb 9, 2015 | 07:44 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Take it to the dealer and complain. Warranty should at least put some new hatch struts on it, but if that doesn't fix it they need to pink sheet it and let MINIUSA know multiple people are having this issue. All they need is for it fall on someone's head.
Old Feb 10, 2015 | 04:50 AM
torpeau's Avatar
torpeau
Don't worry, I will!
Old Feb 10, 2015 | 10:00 AM
talasyn's Avatar
talasyn
I spoke with my dealer yesterday. They said that MINI is aware of the issue but since its not a safety issue, don't expect any resolution to it for a good while.
Old Feb 10, 2015 | 10:37 AM
Mwerness's Avatar
Mwerness
replaced the struts on my older mini...very easy to do it yourself...they do wear out. Enjoy
Old Feb 10, 2015 | 11:27 AM
jeri534's Avatar
jeri534
speaking of the ahtch, do you guys find it intially difficult to get the hatch open when its closed? after that initial resistance its pretty smooth
YaTuSabe
Aug 23, 2018 11:41 AM
OutMotoring
Mar 3, 2017 06:29 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
buggyeye401
Oct 1, 2015 01:22 PM
Suspension Products
Oct 1, 2015 11:53 AM
