F55/F56 Fuel Economy with BMS tune?
Old Jan 9, 2015 | 01:37 PM
SemperMini's Avatar
SemperMini
So I have given up on asking to see if anyone has a dyno table for a MCS with the BMS "tune" installed, but It has been out long enough that I think the people with the product may have noticed fuel economy changes.
Anyone care to weigh in? Better/Worse/Same?
Old Jan 9, 2015 | 02:29 PM
ThumperMCS's Avatar
ThumperMCS
I've noticed no change in fuel economy on my B38 with JB installed...obviously you are enticed to be flooring it more and fuel economy will suffer...but driving around like normal there is no change.
Old Jan 12, 2015 | 03:12 PM
Terry @ BMS's Avatar
Terry @ BMS
There is no change during normal operation as boost is referenced on gas pedal input.
PS. A few B48 dyno results have been posted here: http://www.n54tech.com/forums/showth...t=25245&page=4
Old Jan 13, 2015 | 09:19 AM
randomquickness's Avatar
randomquickness
so is that 289 hp using a DP and catback with no secondary cat or resonator?
Old Jan 13, 2015 | 09:36 AM
George 2014's Avatar
George 2014
No firsthand experience with this piggyback but I can tell you that in my experiences with a tuneable ECU, you may actually see an INCREASE in fuel economy, for the reason that the factory fuel maps are often quite rich in order to protect the motor.
Old Jan 13, 2015 | 12:07 PM
alexmini08's Avatar
alexmini08
I saw on that thread that a member writes +4psi, +5psi, +6psi, etc... Is the user capable of changing parameters in the Stage 1?
Old Jan 13, 2015 | 06:48 PM
SemperMini's Avatar
SemperMini
alright Terry. I am sold. 278 with stock plus your product? Cannot wait until I get through my engine work-in period (I won't install anything until I get 1500 miles under the tires) and I can strap on some extra horses! Throw in a straight pipe exhaust and I am psyched! Almost 300 HP with only two aftermarket products, probably only totaling $1500... insane territory for a MINI!
Old Jan 16, 2015 | 09:11 AM
Terry @ BMS
Yes boost can be adjusted but unless you're on a dyno with full logging & higher octane available I would not suggest changing anything.
Old Jan 20, 2015 | 04:15 PM
Bisquick's Avatar
Bisquick
300whp? I'm down for that...
Old Jan 21, 2015 | 03:27 PM
GregoryK's Avatar
GregoryK
Terry- how about 94 octane and 4 psi? Is it simple to boost it that much? :-)
Old Feb 12, 2015 | 04:53 PM
craigsix's Avatar
craigsix
just installed my bms stage1 beta today. went for a 100mile cruise rite after. knocking down 41mpg hiway on flat kansas roads. other mods are k&n filter 2nd kitty and reso delete, muffler delete with magnaflow ypipe #10778 and dual 2 1/2" tailpipes. sounds nasty. got 500 miles on the odometer now.
AdrenaliNate
Nov 4, 2015 07:26 PM
Aug 27, 2015 12:25 PM
HaveATank
Aug 24, 2015 10:26 AM
flredmini
Aug 12, 2015 06:35 PM
