F55/F56 Berger stage 1 Beta...Oh He'll Yeah
Old Dec 22, 2015 | 07:52 PM
  #126
craigsix's Avatar
craigsix
Originally Posted by honderpilot
Ok thanks, and that's +3.5 for the boost right? Can you also help me with the question above your last response? Thanks man, I really appreciate it!
download to your laptop jb4 then plug into stage1 on your car and get connected then change parameters.
Old Dec 22, 2015 | 07:55 PM
  #127
honderpilot's Avatar
honderpilot
Ok, so it has to be plugged into the car first, gotcha. What are the hex files? Do I need them? Under SETTINGS on the right side of the screen it says "E Series - N54" in the dropdown menu there is an option "F Series All" do I select that or does that not matter?
EDIT: I see that they are firmware. Do I need them? I have the B48 if that makes any difference...
Old Dec 22, 2015 | 08:04 PM
  #128
craigsix's Avatar
craigsix
sorry its been a while you need the updated firmware maybe the hex file once you get it it will show on your computer jb4 hewlitt packard then go to user adjustments.
Old Dec 22, 2015 | 08:08 PM
  #129
honderpilot
I lied I have the B46, is firmware still needed?
Old Dec 22, 2015 | 08:09 PM
  #130
craigsix's Avatar
craigsix
my files say n20/n26
Old Dec 22, 2015 | 08:11 PM
  #131
honderpilot
The drop down menu or the firmware files?
Old Dec 22, 2015 | 08:13 PM
  #132
craigsix's Avatar
craigsix
this is what i like about american muscle my 2015 mustang gt makes over 400 whp with simple bolt ons and simple tuning with way better customer support!
Old Dec 22, 2015 | 08:14 PM
  #133
honderpilot
+1 to the less complicated mods
Old Dec 22, 2015 | 08:15 PM
  #134
craigsix's Avatar
craigsix
on my juicebox4 performance tuner screen.
Old Dec 22, 2015 | 08:19 PM
  #135
honderpilot
Do you have B46 or B48?
Is the N20/N24 under the settings tab? I'm still not entire sure what you're talking about. I'm on the Juice Box 4 Performance Tuner screen.
I'll email Terry if B46 needs firmware or nah.
Old Dec 22, 2015 | 08:22 PM
  #136
craigsix's Avatar
craigsix
i do miss the sporty feel of my mini. test drove a jcw tonite. it felt like a turd compared to my cooper s with +7 psi and good fuel!
Old Dec 22, 2015 | 08:26 PM
  #137
honderpilot
What's the most recent software for the b48. Which file do I download or do I download both: mini b48_1.hex or mini b48_4.hex?
Old Dec 22, 2015 | 08:27 PM
  #138
craigsix's Avatar
craigsix
i had the b46 yes its in the settings tab. im not sure it matters sorry im not computer competent. terry got tired of dealing with me i think. now i can drive a couple miles and get custom dyno tuning in my mustang.
Old Dec 22, 2015 | 08:31 PM
  #139
honderpilot
True, custom dyno tuning would probably yield better performance all around. No worries, I guess it's just my run to bother Terry now...
Old Dec 22, 2015 | 08:38 PM
  #140
craigsix's Avatar
craigsix
do you have the cable to hook the stage1 to your laptop? plug it in and see what happens. it will either connect or it wont. i had trouble figuring out the rite com port to be plugged into.
Old Dec 22, 2015 | 08:41 PM
  #141
honderpilot
I did and it is right now. It's not plugged into the car though, not sure if that makes a difference...?
Boost safety is set at 6.0?
Default Wastegate pos 2?
Fuel open loop is set to 25?
When I try to change it and save it, it displays "settings saved!" and it just reverts back to these settings...
Old Dec 23, 2015 | 08:32 AM
  #142
craigsix's Avatar
craigsix
has to be plugged into stage1 on car open loop isnt rite cant remember default wastegate.
Old Dec 23, 2015 | 09:25 AM
  #143
MarcoPolo's Avatar
MarcoPolo
in response to earlier question, map_1 is an old updated. map_4 is the latest. it fixes issues some people had with the TMAP sensor. you will want to do map_4...but...note that if you are running an old circuitboard, map_1 and map_4 will fail. which means you'll need to ship it back to burger and they'll send you a new circuitboard. but if you're gonna do that, then sh*t, might as well just get the JB4
Old Dec 23, 2015 | 04:22 PM
  #144
honderpilot
What do you mean? Does this affect me? I'm confused.
Edit: you mean the hex firmware files?
Old Dec 23, 2015 | 04:24 PM
  #145
MarcoPolo's Avatar
MarcoPolo
i mean that if you want to use map_1 or map_4, you should be sure that you're not on an old circuitboard or else you'll brick it. how do you make sure? take picture and send to terry.
Old Dec 23, 2015 | 04:29 PM
  #146
honderpilot
There are the maps 0-7? And then there are 2 hex files on n54 tech, the firmware titled mini b48_1.hex and mini b48_4.hex.
Old Dec 23, 2015 | 04:31 PM
  #147
honderpilot
I'm sorry, maybe if you quote the question you're talking about it'll help me understand it's been a long day lol
Old Dec 23, 2015 | 04:32 PM
  #148
MarcoPolo's Avatar
MarcoPolo
disregard maps 0-7. thats for the JB4. i'm referring to those 2 hex files. both require a newer circuitboard. since i bought it very very early i had an old circuitboard. when i upgraded to _1.hex, it bricked. had to send it in to get a newer/updated circuitboard.
Old Dec 23, 2015 | 04:33 PM
  #149
honderpilot
Ok yeah makes more sense now. I thought you were talking about the literal maps but yeah I'm running the _1 hex file.
Old Dec 23, 2015 | 04:36 PM
  #150
MarcoPolo's Avatar
MarcoPolo
if you are on _1 then _4 will also work. that fixes a bug that will trigger a drive malfunction when the TMAP bypass is plugged in.
