F55/F56 Anyone towing an F56 behind an RV yet?
Old Aug 20, 2014 | 06:50 AM
alteredmoods's Avatar
alteredmoods
Hi,
Newb to both MINI and this forum, but have always enjoyed seeing them on the road.
I'm going to start full-timing in an RV next spring and was curious if anyone has had any experience pulling an F56 behind one yet. I know many, many people pull R50/R53/R56 behind them without issue despite BMW saying it's a no-no. I'm strongly considering buying an F56 for my toad as it's a better alternative to the (boring) Honda Fit and the (less boring) Ford Focus.
Any experience or input on an F56 lash-up to an RV would be welcome.
Thanks.
Old Aug 20, 2014 | 08:14 AM
Mrdi's Avatar
Mrdi
We were advised upon purchase that it was not to used as a toad.
Front wheel drive?
Will you put the front wheels in a cradle?
Old Aug 20, 2014 | 03:15 PM
alteredmoods
Front wheel drive?
Nope, wasn't planning on it...too much extra stuff and inconvenience for not much benefit. I can buy a new Focus and lash it up without an issue, but I strongly preferred the Mini.
I'm also considering buying a used late model MCS.
Do you own an F56?
Old Aug 20, 2014 | 08:14 PM
Mrdi's Avatar
Mrdi
We have an MCS F56 manual
Try this:
http://prodcontent.s3.amazonaws.com/2014DinghyGuide.pdf
I would also call the Mini dealer near you and get their opinion.
When told by our dealer not to tow/toad/Dinghy our Mini, we had no intention of doing that .
We didn't pursue it. .
Old Aug 21, 2014 | 09:57 AM
alteredmoods
I'm well aware of that guide. It's how I know a Focus can be towed four-down without impacting the warranty.
I'm willing to take the hit on the warranty to drive an F56 if it's the same 'wink/nod' type deal that I've seen people experience when towing R5x Minis.
If they're telling you up front that you shouldn't toad it then perhaps the going opinion has changed somewhat. In that case, I'll either pick up a used Mk 2 or buy another brand.
Any additional experience on toading an F56 is more than welcome.
Old Aug 21, 2014 | 10:38 AM
Mrdi's Avatar
Mrdi
( I have no documentation) The reason for non Toading status is that the engine needs to be running in order for the moving parts that would be active under tow are lubricated.
It seems a used Mkll might be the prudent direction, unless your inquiry from BMW produces a wink/nod .
Old Aug 21, 2014 | 12:57 PM
hammerhands's Avatar
hammerhands
There must still be new R56s out there too.
Old Oct 25, 2014 | 09:56 AM
BRP27's Avatar
BRP27
If you are towing a Manual Trans car I don't see an issue. A auto trans will build up heat that will be a problem but a manual the only I issue I see is the trans slipping into gear while towing. Not very likely to slip into gear on its own IMO
vulkandino
Oct 31, 2015 08:29 PM
papawhiskey
Sep 30, 2015 02:50 PM
Tisaksen
Sep 28, 2015 11:30 AM
Sep 25, 2015 12:32 PM
