F55/F56 So...I'm an idiot. Curbed.
Old May 17, 2014 | 04:08 PM
JohnBLZ's Avatar
JohnBLZ
Got distracted by the wife for a brief second pulling into a spot.
How can I best clean this up? What's the paint code for these wheels?
Old May 17, 2014 | 04:53 PM
TouchUpDirect's Avatar
TouchUpDirect
Link is broken for me, can you re-post a pic? What color are the wheels, I can probably do a little research to figure out the code and/or color name.
Old May 17, 2014 | 05:51 PM
CobraBob's Avatar
CobraBob
Yeah, it's not working for me, either. If they're the black wheels, you should be able to fix them. My dealer scraped my passenger side front wheel on a new curbing at the dealership. They touched it up (but insisted on ordering me a new wheel) and I honestly couldn't see the repair. So if you have the black wheels like me, you can probably have them nicely repaired.
Old May 17, 2014 | 06:13 PM
ojedam64's Avatar
ojedam64
Ouch....not sure if there any touch up paint that will fix that
I copied the pic and attached it for you.
Old May 17, 2014 | 06:20 PM
JohnBLZ's Avatar
JohnBLZ
Many thanks! I figured I'd need to buff it smooth at a minimum before painting.
Old May 17, 2014 | 06:26 PM
TouchUpDirect
We can certainly figure out the wheel color, but are you familiar with the mobile wheel repair services out there? They can fix that and make it look damn near perfect for like $100-$150. Where are you located?
As far as the color code goes, I believe it's going to be A54, Bright Silver. I just looked it up and it seems to be the only silver Mini is using the last couple of years for wheels.
PM me if you want to discuss some touch up options (it's what I do, but I don't want to sound like I'm just trying to sell you something on the forum). We can confirm the color and figure out what you need. This is if you don't want to go with the mobile wheel repair, of course.
Old May 17, 2014 | 08:14 PM
Mrdi's Avatar
Mrdi
It seems the tires no longer accept the curb rash before the wheels are damaged??
Old May 17, 2014 | 08:16 PM
Mrdi's Avatar
Mrdi
Ojedam,
Was that a substantial curb attack or just a slight rub?
Old May 17, 2014 | 08:50 PM
Conrad_Thomaier's Avatar
Conrad_Thomaier
You guys are a bunch of car nuts. You're interested in the car damage and I'm interested in what his wife did to distract him :-)
Old May 17, 2014 | 09:08 PM
Mrdi's Avatar
Mrdi
A rub by rub description.
Old May 18, 2014 | 08:55 AM
ojedam64's Avatar
ojedam64
Originally Posted by Mrdi
Ojedam,
Don't know, it wasn't my damage, I just reposted the picture for him because everyone kept saying they couldn't see the link
Hope you get it fixed, sounds like there are some good solutions out there.
Old May 18, 2014 | 01:37 PM
JohnBLZ's Avatar
JohnBLZ
Ojedam,
I knew the wording would be open to interpretation, but let me clarify. Nothing worth getting a wheel curbed over
Old May 18, 2014 | 01:38 PM
JohnBLZ's Avatar
JohnBLZ
PM'd
Old May 18, 2014 | 01:52 PM
JohnBLZ's Avatar
JohnBLZ
MINI's (especially w/ the run flats) have always been bad about it.
Old May 18, 2014 | 02:31 PM
Helmincamaro's Avatar
Helmincamaro
I did it within 24 hours of ownership..... Black paint and the polished rim too!! Super pissed off!
Old May 18, 2014 | 03:48 PM
StevenZoz's Avatar
StevenZoz
i feel your pain, i did the same on the same wheels
Old May 18, 2014 | 07:59 PM
cjjca's Avatar
cjjca
Check out Blackburn Wheels (blackburnwheels.com). We deal with them where I work. Wheels look brand new, but they are reconditioned.
Old May 19, 2014 | 08:49 AM
DrewN's Avatar
DrewN
This one helped me out a lot when I had Rota RBs with polished lip:
http://www.clublexus.com/forums/auto...ix-it-now.html
Unfortunately the silver OEMs are not as easy to fix.
Old May 19, 2014 | 09:05 AM
minibx's Avatar
minibx
OP don't over think it, just search for a good wheel repair shop in your area and they will match the paint and repair it, I personally go for the shop that will remove the tire to do the job, if they don't do that it doesn't work for me. It will cost you 100 to 130 or so as advised above
Old May 19, 2014 | 11:23 AM
GregoryK's Avatar
GregoryK
Not Sure where you are located. I have repaired rims with good success. I filled the scrapes with JB Weld. Need to make a couple of passes and get down to 400 grit. Spray primer - mask of the rest of the wheel but feature the spray in. Then get a spray can the same colour. I use Silver bright metallic on my R56 rim. Not sure if the new rims will be the same colour. ..but you nee a good match. 4 light coats of clear coat. Sanding in between coats is really important. After all this only you will know..
There are some good post on the BMW sites ...just google Curb rash repair.
The rim guys are expensive and if you want to get it powder coated - like the original it cost more.
Also it is way easier if you pull the wheel while you work on it!
Good luck.
Old May 19, 2014 | 11:27 AM
GregoryK's Avatar
GregoryK
Oh yes . Of course you need to mask off the tire!
Old May 19, 2014 | 12:27 PM
JohnBLZ's Avatar
JohnBLZ
Good luck.
Thanks... might give it a shot if the mobile repair solution is too much $$
Old May 19, 2014 | 12:33 PM
GregoryK's Avatar
GregoryK
The cost of the DIY solution is so cheap that you can always call them if you are not happy. Dude - this will bond you and the car - part of the fun of having a Mini Cooper _ IMO!
Old May 19, 2014 | 04:06 PM
afadeev's Avatar
afadeev
You will need to both smooth the damage, and fill in some of the ruts with putty/filler. I've heard good feedback from people who used Bav Auto's kit, though haven't tried it myself yet:
http://blog.bavauto.com/15365/bmw-an...im-repair-kit/
http://www.bavauto.com/shop.asp <-- search for "wheel repair"
a
whowantstorace
Sep 27, 2015 06:16 PM
one73ronin
23
Sep 22, 2015 09:56 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
agile_moments
Nov 4, 2008 11:12 AM
AliceCpr07
DC Metro MINIs (Archive)
54
Sep 7, 2008 08:51 PM
