F55/F56 Coilovers...
Old Mar 10, 2015 | 08:02 AM
  #201
SoCalledFriend's Avatar
SoCalledFriend
Originally Posted by VicSkimmr
What's the size/offset on the stock JCW wheels?
18x7 et54
Old Mar 10, 2015 | 08:09 AM
  #202
VicSkimmr's Avatar
VicSkimmr
It's a tough call with 215 series tires since they're wider than the wheels are. 12mm should be good I would think. You'll need longer bolts (might be a good time to convert to studs).
Old Mar 10, 2015 | 08:11 AM
  #203
SoCalledFriend
I'm not married to the 215's....should I stick with the 205's? There just seems to be more tire options in the 215 size (I need All Season High Performance).
Old Mar 10, 2015 | 10:33 AM
  #204
VicSkimmr's Avatar
VicSkimmr
I don't mean that they're not good, they're just wider than the wheel so it's a bit tougher to guess what size spacer you should use.
I'd say buy a pair (just 2) of 12mm spacers to try. If they look awesome in the front, then I'd get a set of 12-15 spacers for the rear. If the 12mm is too much for the front, move them to the rear and get something in the 8-10 range for the front. I'm pretty sure the BC coilovers come with a 5mm spacer too, so you could try that out.
Either that or wait it out and get some 3mm thick washers off amazon to test fit them. You can stack them to get a better idea of what size spacer you'll need. Just don't drive on them like that.
Old Mar 10, 2015 | 06:07 PM
  #205
SoCalledFriend
I need to wait for the final specs on the fJCW wheels. I was going off the JCW wheels that are an option with the JCW Aero Kit. Word on the street (straight from MINI USA) is "Although the Track Spoke and the Cup Spoke Wheels are offered on F56 Copper and Cooper S if you order the JCW Exterior Package (7KN), the actual wheels you'd get are different from those on the fJCW. The wheels on this car are differently shaped inside to accommodate the larger brake calipers."
I don't know if that will affect the offset/one way or the other?
Old Mar 11, 2015 | 02:15 AM
  #206
R99's Avatar
R99
Offset is not affected I believe.
The spokes bend outward to accommodate the brake caliper. Why MINI didn't just go wider is anyones guess, instead they have also fitted those poorly designed arch extensions which look like a Friday afternoon rush job!
Old Mar 16, 2015 | 01:14 PM
  #207
randomquickness's Avatar
randomquickness
anyone find updates on the ST-XTA or KW Clubsports? I just did a little browsing and not having much luck.
Old Mar 16, 2015 | 01:17 PM
  #208
oc cj's Avatar
oc cj
I was able to confirm direct with KW in Germany that the ST kit available from tuner shop is an error. No ST kits are available at this time.
Later, tunershop confirmed the same thing and thank me for pointing this out to them.
I've asked KW if ST kits are being developed and am awaiting a response.
Old Mar 16, 2015 | 01:51 PM
  #209
randomquickness
looks like the clubsports are up on the german kw site and they are as expensive as I had expected...
http://www.kwsuspensions.de/produktf...terGroupID=1-2
Melangell
Aug 20, 2012 12:56 PM
jcw_ee8
Sep 8, 2009 10:52 AM
miniman101
Suspension
39
Jul 17, 2009 07:57 AM
