F55/F56 Coilovers...
Sure pm me and give me your number and I'll text you some , they are still in the box tho but I'll send you pics with a piece of paper saying my username so you know in legit
I know man, go ahead and order bc that 3 week wait time is gonna feel like forever. Im stoked bc I really didn't want to have to go with kw v1s without dampening adjustments and very limited ride height adjustment
If BC recommend a 5mm spacer, I assume KW will too (no info from KW!)
This means for my 18x8 ET45 wheels to fit a 10mm spacer is going to be needed to equal the same fitment as the OEM rims with a 5mm spacer.
Putting them at 18x8 ET35, which may well be touch and go with rubbing etc I think!! :(
Here's are my questions. I'm thinking about buying these same BC coil-overs and lowering the car about 1-inch or less. In this case, are camber plates advised? Does BC offer the camber plates, if so how much? If not, would another brand of camber plates fit? Who sells these and how much do they sell for? Would handling and tire wear be improved with the addition of camber plates? Did you get a price onthe wheel spacers you'd mentioned. I'm trying to get an idea as to howm much I need to save.
Thanks.
Kevin.
Well I'm sad to say the $1000 I had set aside for the coilovers went up in smoke this morning. My french bulldog who is allergic to everything got stung by a bee and went into shock and we had to rush him to the ER. $900 and 5 hours later I'm glad to say he's doing better. I love my dog so it was money well spent, I'm just sad I'm gonna have to wait on these coils. I'm stoked to see some pics when you guys all get yours on. Keep us updated
I'm considering the BC coil-overs and lowering the car about 1 or maybe 1.5 inches. In this case, are camber plates advised? Does BC offer the camber plates, if so how much? It was mentioned that wheel spacers would be needed. Who sells these?
I'm trying to get an idea as to how much to budget for the suspension upgrade.
Thanks.
Kevin.
Thanks.
Kevin.
The coil overs do not come with camber plates (to my knowledge) you will need 5mm wheel spacers to clear the dampers front and rear as the bc dampers will be wider. Usually up to 5mm spacers are not required to be hub centric as the stock hub ring will be longer than 5mm however I have yet to actually measure it. I would advise you to call ecs tuning and they will get you what you need
Thanks.
Kevin.
Thanks.
Kevin.
How about the other way- what's the max spacer that can fit with stock wheels? Anybody have info?
Hm I wonder why bc states the need for spacers.. Unless they just use a wider strut. I honestly can't remember if they recommended them for just the front or front and rear. Looks to me like the rear has a bit more clearance than the front in stock form
I don't think anyone's gotten them. Ordered mine a week ago and was told it would be 2 to 3 weeks on shipping. As far as I remember I was the first one on the forums to order. Soon as I get them I'll install them and post pics
I'm also looking for feedback on the ride quality. I've used KW, ST, JRZ, Eibach, H&R...Never tried BC as my first impression was that the quality was lacking but from what I've read they seem to be doing quite well for the price.
