F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
2015 F55 axel popping
Old Apr 12, 2023 | 06:09 PM
Mr Meowgi's Avatar
Mr Meowgi
My 2015 Mini f55 is telling me something. And it sounds expensive. This is the section where it retreats into the transmission i assume.
I see a few different axels Online. But do I need a half axel or would this be the outer? One side is the axel nut through the hub. How is the other side attached internally where it's clicking?
And is this a job that one person can do on a weekend. Done a lot of Mini stuff. Just no CV axels or transmission work.
​​​​​​Thanks in advance
https://youtube.com/shorts/22CrbVO9Qu0?feature=share
Old Apr 13, 2023 | 09:37 AM
TVPostSound's Avatar
TVPostSound
There's a circlip on the spline shaft going into the trans,
you should just be able to pop it out with a pry bar wedged between the housing, and trans.
Old Apr 13, 2023 | 09:39 AM
TVPostSound
Are the boots ripped, and leaking grease??
Old Apr 13, 2023 | 10:03 AM
Mr Meowgi's Avatar
Mr Meowgi
I didn't see any rips but there was some grease at the first CV boot closest ti the wheel. So it probably needs work anyways..
Old Apr 13, 2023 | 12:08 PM
cjv2's Avatar
cjv2
Definitely shouldn't be any grease "just sort of around" and given the proximity to the CV boot and the clicking, the boot is likely torn (and the grease from within).
Old Apr 14, 2023 | 01:09 PM
TVPostSound
Most of the time its the outer joint (towards the wheel) and it results from lack of grease.
As cjv2 mentioned above, is it clicking, on turns?? Then it's the outer.
Old Nov 7, 2023 | 06:10 PM
JasonBroker's Avatar
JasonBroker
Hi Mr. Meowgi,
did you find a solution? I have a 2016 F55 S Automatic and I see the same symptom. I will pull the axles tomorrow to investigate further, but it sure seems like something is really wrong inside the transmission.
My son was driving the car we he heard a loud 'pop' upon acceleration and then no more power to the wheels.
Old Nov 8, 2023 | 03:39 AM
Mr Meowgi's Avatar
Mr Meowgi
I ended up needing the CV axle itself. the circlip on the very end that holds it into the transmission was worn down .
so I didn't worry about just trying to replace circlip. I just installed new axle I'm on the driver's side, because with my luck I felt like somehow I'd have to do it twice so I just put the whole new axle in
Old Nov 8, 2023 | 08:28 AM
Thanks for the info.
Old Nov 8, 2023 | 05:16 PM
JasonBroker
So, got home today and went to work. Pulled the Driver's side axle (the one that was wobbling) and the end of it is sheared off! Clearly not the same problem you experienced - I'll start a new thread.
One question, when you removed the axles, did fluid drain out? Mine did not, I am concerned that low fluid may have led to the broken axle.
Old Nov 18, 2023 | 04:17 PM
Mr Meowgi's Avatar
Mr Meowgi
I had very minimal trans fluid leak out when I pulled the axel. I expected more to drain out. But I couldn't really find much instruction on the Gen 3 so I just went with it.
Added back what fluid did drain out. But making sure the trans fluid is correct is another process by itself.
I swear if I didn't love my two Mini's I'd figure out a way to strangle them. Lol.
Old Dec 8, 2023 | 11:00 AM
For the F55-F56-F57 1.5L (just a Cooper) GSP now has axles. Only other ones are Genuine MINI which are $$$ and seem to fail.
https://www.ecstuning.com/Mini-2014-...s/Right_Front/
For the F55-F56-F57 2.0L S We have these aftermarket options now.
https://www.ecstuning.com/Mini-2014-...vetrain/Axles/
DudskieG
Aug 28, 2019 04:11 AM
BbyDenns
Jun 7, 2018 06:38 AM
Minicrazy1234
Aug 29, 2017 08:36 PM
Jonelew
Sep 10, 2015 05:52 PM
6thGear
Feb 21, 2014 09:44 AM
