F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Mini Cooper s p2421 vent valve open
Old Sep 25, 2016 | 09:15 PM
Chris266's Avatar
Chris266
hey my check engine light is on , code is p2421. any ideas what's causing the problem ? please
Old Sep 27, 2016 | 11:41 PM
Eid2000's Avatar
Eid2000
This indicates that the vent valve or vent valve control circuit of the EVAP control system is no longer functioning properly. The EVAP system consists of components including (but not limited to) the gas cap, fuel lines, charcoal canister, purge valve, system pressure and flow sensors, electrical wiring and connectors, vacuum lines, the fuel tank, and fuel vapor hoses.
Check fuel cap cover ,
Old Sep 28, 2016 | 07:42 AM
Chris266's Avatar
Chris266
thanx a lot
Old May 27, 2021 | 04:06 PM
vexingv's Avatar
vexingv
i'm having this issue, although with a 2013 R60. how was your issue resolved?
Old Jun 10, 2021 | 02:43 PM
JlScottMacDonald's Avatar
JlScottMacDonald
When I had this issue I just needed to pull my gas cap off, clean the seal on the cap, and put it back on. I had to do this a few times after getting the car from the dealership, maybe the gasket rubber was a little stiff and in need of working-in.
Old Feb 23, 2022 | 04:35 PM
MINI Duke's Avatar
MINI Duke
I just replaced the fuel tank rebreather valve and it worked!!! No more hesitation starting up after putting gas and no more eval leak code!
Attached Thumbnails Mini Cooper s p2421 vent valve open-057b891d-5e18-4064-9856-c2539ef69759.jpeg
j-gregs
Feb 15, 2023 07:41 AM
Fred Heiler
Jan 28, 2020 03:41 AM
suntaepark
Dec 28, 2013 07:31 PM
mikeym
Jan 6, 2013 05:40 AM
ronstoys1
Jan 21, 2007 05:30 PM
