Code P0444, EVAP CONTROL PURGE VALVE C OPEN
Old Dec 23, 2013 | 02:51 PM
suntaepark's Avatar
suntaepark
Ah.... another code has been thrown at me.
P0444, evap control purge valve...
Checked the gas cap, checked the wires goes into the purge valve.
I am guessing it must be the purge valve itself???
any other possible areas that I may want to check before I order that part????
Old Dec 26, 2013 | 03:01 PM
Nitro Jake's Avatar
Nitro Jake
that valve is a simple on/off solenoid that is normally closed with no voltage applied. if you cap one end and apply vacuum (with a pump or your mouth AT YOUR OWN RISK) it should remain closed and hold vacuum. if it does not hold vacuum, the valve has failed. if it holds vacuum, the control side of the valve (ie the power source and/or ground is at fault.
Old Dec 28, 2013 | 07:31 PM
RA082324's Avatar
RA082324
part# delphi 1997278
from autozone
$22
had the same problem. this fixed it.
theres another thread on this issue already as well.
damncajun
Aug 17, 2015 08:25 PM
Emnotek
Aug 13, 2015 05:47 PM
skippermini
Aug 13, 2015 06:13 AM
pocketmaster
Aug 6, 2015 01:41 PM
