F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 hi/low beam malfunction error
Old Apr 24, 2020 | 07:02 AM
brownaves's Avatar
brownaves
update: the bulb harness is melted (and some wire exposed...not sure that is a big deal). Can I just replace the harness?
Hi Everyone! I am new to the forum. I have a 2017 F54 base and a little over a month ago, I got a hi/low beam malfunction error. The left headlight has no problems. The right one is cloudy and seems to have condensation in it. It was randomly working and now nothing. Any ideas on what the issue could be? Do I simply need a new headlight assembly, or is this going to turn into jumping down the rabbit hole of electrical problems? I have already had the right brake light assembly socket melt and it was replaced (under warranty), so I am worried that this car might have electrical issues. Of course, I am now out of warranty with almost 64K miles. I also have heard about issue with the foot well module. Any ideas you all might have would be appreciated. Trying not to spend a fortune right now!!
I get both low and hi beam malfunctions
left headlight is crystal clear
right headlight is all cloudy (appears to be inside)
Old Dec 16, 2022 | 05:39 PM
goclubman's Avatar
goclubman
@brownaves Having the same issue with my 2017 Clubman now - My left headlight has the same look as yours, I do see some exposed wiring on the inside of the headlight itself, and I did notice an almost burning smell from it (The headlight error just happened and I checked as soon as I made it home). Did you end up getting this sorted on your own or did the dealership have it replace anything? Curious how to proceed with this myself.
Old Dec 19, 2022 | 11:58 AM
https://www.ecstuning.com/b-flosser-...each/4445~fls/
I would use a little dielectric grease.
https://www.ecstuning.com/b-american...cket/cp-1~ags/
Stock bulb or a high wattage aftermarket bulb like 100W?
q-uest
Jun 19, 2024 04:40 PM
mini4door
R60/R61 Stock Problems/Issues
Jan 28, 2013 06:15 AM
jbewley
Jan 29, 2009 09:29 AM
115hp
Oct 24, 2004 07:38 PM
Servoman
Sep 17, 2002 02:32 PM
