F54 Adding alarm to 2017 Clubman
on
I've got to believe dealers have a way to boot up the alarm (or some sort of aftermarket alarm that is compatible) as there must be many buyers who want the alarm feature added.
Start here: https://www.shopminiusa.com/PRODUCT/...-ALARM-SYSTEM#
Will have to check with a dealer. Thx.
on
Please let us know what the dealer says. The Alarm was a $500 option with a factory order, so that should give you a price range.
She pulled the trigger!
Now, can we add an alarm?
RealOEM says PN 65759383320
http://www.realoem.com/bmw/enUS/show...diagId=65_2599
ECS Tuning - is that NLA as I see on your site?
Just saw this, Checking with MINI as its very new.
I'll let ECS Tuning confirm, but I do believe you can retrofit it. I'm guessing the hardware (i.e., the siren, and locking/unlocking sounds) will work out-of-the-box. However, I believe you have to code the VO to add the alarm option code to get the alarm to fully function. Did this on my BMW, but this was back in 2011 or so.
The new part is 5759493759 and yes we can get them.
https://www.ecstuning.com/b-genuine-...759493759~oem/
Welcome.
Hi
227 thats the cost of the whole alarm system ? factory mini alarm?
Thank you!
Yeo, its holds the tilts sensor, I have not seen a MINI with that already installed, same with the install hardware, just make sure its prewired up there, you should have a little plug hanging out or it might be wrapped in the main harness up there just like the older MINI models.
Yes, hold on. Found it.
https://www.newtis.info/tisv2/a/en/f...tem/1VnYjwwcTN
https://www.newtis.info/tisv2/a/en/f...tem/1VnYScSnt4
https://www.newtis.info/tisv2/a/en/f...tem/1VnYM98Els
So based on what newtis shows, the ultrasonic interior sensor is already integrated into the overhead control module and monitors the latches and hood for possible breaking and entering into the car. Therefore all that'd be needed is the tilt sensor/alarm and install it in the rear trunk area, then program?
Let us know, Thats all the info I have, my guess is that its those parts and a flash. Based off the older MINIs and what MINI is doing on the wiring harness side on future generations I bet its parts and a flash update to the ECM.
