F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 2017 Clubman S non-LED- Convert to LED?
Old Sep 25, 2017 | 04:33 PM
m3moser's Avatar
m3moser
Hi folks- Being a new owner and just having picked up my Clubman S on a year end special, I had to take something off the lot. The car did not have the LED headlights. Rather it has whatever are the standard which I find far less safe then the Xenon units in my other car (BMW).
Is it possible with a LED bulb upgrade to swap out the headlight bulbs in these cars and get one of the many LED bulb kits I see. If so, has anyone done it and is there a brand or model of bulb that is recommended?
The headlights on mine seem to have one bulb or perhaps its a two element bulb in one housing?
Old Sep 26, 2017 | 08:01 AM
m3moser's Avatar
m3moser
Found my own answer. Due to the headlight housing, switch to LED bulbs will not give the correct dispersion pattern, so a different bulb upgrade is used. See here:
https://www.northamericanmotoring.co...placement.html
Old Sep 26, 2017 | 08:17 AM
Ray Oliver's Avatar
Ray Oliver
I upgraded my wife's Cooper with those bulbs and there was a noticeable improvement.
Old Dec 11, 2017 | 04:13 PM
goclubman's Avatar
goclubman
Did you end up going with the H4 or H7 bulbs for the main headlights? And what bulbs did you select for the daytime lights on the bottom? This is also the look I am going for
Old Dec 12, 2017 | 06:24 AM
m3moser's Avatar
m3moser
I went with the H4 (9003) at this link:
Sylvania SilverStar ZXE 9003/HB2 H4 Bulbs on Amazon Sylvania SilverStar ZXE 9003/HB2 H4 Bulbs on Amazon
I did not do DRL lights, don't really care about those too much, just wanted better night time lighting. I would say that the results to my eyes are NOT spectacular. I know there may be dispersion problems with using LED bulbs in the Non LED headlight housings, but next I am going to try these:
Amazon Amazon
This is a real LED bulb. We will see if it causes other drivers problems. My basic gripe is that all the Mini cars, at the prices these cars go for, should come standard with LED lights, not only as an option. I mean if they look at the their lower priced competition they have today, most every car manufacturer has very good LED or Xenon lights as standard. Pain to have to be DIY fixing what should not need to be upgraded in the first place. My rant is now over.
Old Dec 12, 2017 | 06:00 PM
peterpan101's Avatar
peterpan101
Originally Posted by m3moser
my basic gripe is that all the mini cars, at the prices these cars go for, should come standard with led lights, not only as an option. I mean if they look at the their lower priced competition they have today, most every car manufacturer has very good led or xenon lights as standard. Pain to have to be diy fixing what should not need to be upgraded in the first place. My rant is now over.
While I agree they should be I'd say vast majority are still optional. Even the C class and 3 Series and others have halogen standard. Yes a few do like the Corolla, but from what I've seen that's the exception not the rule
Old Dec 12, 2017 | 06:14 PM
iwashmycar's Avatar
iwashmycar
Old Jan 9, 2018 | 08:21 AM
xentar's Avatar
xentar
or if you can spend a bit more $$$... you can also get a 3rd party headlight replacement (plug & play) like I did. here's the thread where I showed what I did on my F56 MCS..
https://www.northamericanmotoring.co...ml#post4305824
Old Jan 9, 2018 | 09:05 AM
goclubman's Avatar
goclubman
And F56 headlights will work on an F54 2017 Clubman? Just confirming
Old Jan 9, 2018 | 10:29 AM
xentar's Avatar
xentar
I believe they will, unless something has change on the 2017 F54 headlight housing..
