Electrical FOG LIGHTS
Old May 2, 2007 | 10:45 AM
RaT48's Avatar
RaT48
FOG LIGHTS
[FONT=Times New Roman][SIZE=3]I wanted to change the bulbs in the original fog lights, the original ones look yellow and ugly. I was hoping to buy some that would be the same watt to avoid a lot of problems but a similar color to the xenon lights? Does anyone know where and what kind of light bulbs I need and how do you switch them, because it’s going to be tight to get in there! [/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3] [/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3]Thanks![/SIZE][/FONT]
Old May 2, 2007 | 11:03 AM
kapps's Avatar
kapps
The stock fogs are H7. If you want to match the Xenons, look for a color temperature around 5000K. Replacing them shouldn't be too bad. Jack the front of the car up and remove the wheels. You need to take the inner fender liner off or at least bend it back enough to get to the back side of the fog lights. It's held on by pop rivets (unscrew the center and pull the rivet out). Once your in there, you can clearly see the fog light connector. It should be pretty easy to figure out from there.
Old May 2, 2007 | 03:17 PM
IrishCooper's Avatar
IrishCooper
actually the foglights on my 06 MCS are H11s. I wouldnt think other Gens would be different
Old May 2, 2007 | 06:38 PM
kapps's Avatar
kapps
Oh, yeah, I forgot...the '02's and early '03's were H7. They changed over to H11 in '03.
Old May 2, 2007 | 06:44 PM
RaT48's Avatar
RaT48
I have an 06 MCS so that would apply to me. The other thing that I'm concerned about is any problems. my friend decided to switch his bulbs in stock head lights and he had some problem. He bought a pair for about $50 and 2 days later one of the bulbs melted, messing up his whole light. Will there be any problems if I switch my fog lights??
Thanks Guys!
Old May 2, 2007 | 07:29 PM
kapps's Avatar
kapps
As long as you stick with the right wattage (55w), you shouldn't have any problems. Increasing the color temperature has the possibility of causing problems but you'd have to go above 8000k (purple) before worrying about that.
Old May 2, 2007 | 07:33 PM
RaT48's Avatar
RaT48
I was thinking about 5000K like you said! And one more light bulb realted question what i the name of the front turning singnal bulb because I wanted to get those in white?
Old May 2, 2007 | 07:43 PM
kapps's Avatar
kapps
I'm not completely sure, someone else may be able to help you out with that one. I think it's called a bayonet. Do a search, I'm pretty sure there will be threads on this topic.
Old May 2, 2007 | 08:24 PM
RaT48's Avatar
RaT48
Thanks! I also wanted to change the reverse light bulbs, i know you don't really see them a lot but it makes me feel better. lol.
Old May 2, 2007 | 08:58 PM
roaduscarnivorous's Avatar
roaduscarnivorous
i actually want to change my fog bulbs to piaa yellow h11's, which run at 2500k. it's a 55w bulb but they claim to produce up to 110w. would this melt my housing?
Old May 2, 2007 | 09:35 PM
RaT48's Avatar
RaT48
I was looking for the h11's and found the hyper white one with 5000K that also claim to produce up tp 110w and I'm scared that something might melt! I'm also looking for an answer!
Old May 2, 2007 | 09:49 PM
DjR53's Avatar
DjR53
nope and i think piaa is a very good company
Old May 3, 2007 | 07:07 AM
kapps's Avatar
kapps
DjR53 is right, it's still just a 55w bulb. If you like the PIAA yellow's and don't want to pay and arm and a leg, look for Nokya bulbs on Ebay. I got some H3's for my Hella fogs for <$25 and I haven't had any issues.
Old May 4, 2007 | 06:47 AM
shooler's Avatar
shooler
I have had the Nokya H11 yellow bulbs for a couple of years now. I got them on Ebay and have had no problems with them at all. As with any halogen bulb, use denatured alcohol and a clean microfiber towel to remove any traces of oils (from your hands), or other contaminants.
Old May 7, 2007 | 05:01 PM
Wake|MCS's Avatar
Wake|MCS
My 06/02 build has H11's for fogs...
Old May 7, 2007 | 05:34 PM
kapps's Avatar
kapps
Interesting...honestly, my 06/02 build also has H11 but at least one was replaced after an encounter with a tree limb during the hurricane season a couple years ago. I always thought they replaced both of them but maybe they were H11 to start with. The Bentley manual says they are H7 as do a few other places I've checked.
Old May 9, 2007 | 03:59 PM
Wake|MCS's Avatar
Wake|MCS
Yup, my owner's manual says H7 to. I bought bulbs without checking first and ended up using those in my high beams. Now I'm just going to run HID fogs. I've had one in there for quite some time and all is good, sharp cut-off and everything. Plus they actually match, can't go wrong...
Old May 9, 2007 | 04:16 PM
ScottRiqui's Avatar
ScottRiqui
No, you don't have to worry about your wiring. The confusion comes from the fact that automotive bulbs are generally classified by how much power they consume (Watts), not how much light they produce (lumens). "Lumens per Watt" varies greatly, depending on the technology used in the bulb and the color temperature (2500K, 4200K, etcetera).
As an extreme example, consider the burner coil on your stove. You can think of it as a light bulb with an exposed filament. Even though it may consume hundreds of Watts of power, most of it is being released in the form of heat and infrared light, which is why you get less illumination from a stove burner than you do from a 5W nightlight.
In your case, the manufacturer is simply claiming that their 55W bulb produces the same amount of light as a 110W bulb from some other manufacturer. But since they consume the same 55W as the stock bulbs, your wiring won't be in any danger.
Old May 10, 2007 | 06:30 AM
tekron's Avatar
tekron
Be weary about replacing your main headlights and high beams with just HID bulbs. I just bought 4 for my main headlights and fogs and it is considerably harder to see at nite with them in because they're actually dimmer. I don't think the reflective housing in the headlight assembly reflects the HID light as well as the OEM bulbs...
Old Jun 23, 2007 | 08:37 PM
howsoonisnow1985's Avatar
howsoonisnow1985
+1
I did by those cheaper "HID" before and they are worse than oem they look cool though and they even "look brighter" from outside. Although I did get the PIAAs for my fogs on the MINI after oems went dim, and they are alot better than my old nokyas and oems but they were pricey, but the place I got them says they got a 1 year warranty? Now I am switching to H7 Orsams Ralley 65watt for Highs and H9 Orsam 55w+ for fogs. These are the Euro versions of the Silverstars. Folks on ralley and Land Rover type site say they are the best!!! Guess I'll give em a try? (apparently you could put H9s in place of H11s??) Just depends if you want the "cool blue/purple" look or just some strong lights:impatient MINIS so bright I gotta wear
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 21, 2015 12:50 PM
Aug 19, 2015 12:51 PM
