Electrical New idea for a brake light mod
As you are aware I don't trust the standard rear brake light mod (jumper/diode). But I was wondering if anyone has tried this idea? How about putting a bit of electrical tape on the contact for the brake light dual element bulb and then installing the jumper/diode so that when the brakes are pressed only the top (fog) light is illuminated. When the running lights are turned on then only the lower light would illuminate. This way when the brakes are pressed only the fog lights would light up, eliminating the possibility of drawing to much power trying to light up both lamps.
As has been posted before, I know of 2 folks personally that had warranty repair denied for a problem with the BC1 module because of your mod. No way of determining with certainty if this caused it or not, but I don't want to take the chance.
I've had it for a year or so - love it, no problems.
I beleive it was Great Bear that showed how to do a cut and patch to swap the brake lights and fog lights.
I just backed the terminals out of the plugs, and swapped the fog light and brake light terminals, thus had the fog lights acting as brake lights.
Similar to this photo, which is actually a photo of my trailer light hook up.
http://user.mc.net/~jdewey/MINI/Trai...MINI_wires.jpg
I later put them back. I currently have a "POWERED trailer light" adapter driving the "fogs" as brake lights, and the regular brake lights running normally.
John
John
Wont the dealer see it as a mod to the system is a mod to the system therefore they shouldn't have to pay the warranty repair costs?
If you did the more conservative version of the mod (post #5) and the BC1 still blew up, the dealer may try to deny warranty if they discovered the mod. However that version of the mod does reduce risk of damage to the BC1 to essentially nil, because no additional wattage is used. Full brake light mod = more benefit, some risk. Half brake light mod = some benefit, almost no risk. You choose the amount of risk that you are comfortable with.
MyMiniparts.com sold me the read brake light kit for 12 bucks. YES, I know you can go to Homedepot and build yourself for a few bucks but time is money. The kit had self wire tap ends - find the cables, attach ends and squeeze with pliers. Took me 15 minutes to do the first side and 2 minutes to do the other.
It has worked flawlessly for over a year. Could be easily removed leaving little evidence.
dealers and warranty - reach is different
What problems have you heard about involving LED bulbs? In a tail light, a replacement LED bulb may not be as bright as a regular bulb or have a focused hot spot, but I wouldn't expect any issue with the BC1.
For the brake light mod, no LED flickering issues if you replace only the top (fog) bulbs with LEDs. They would be in a parallel circuit with the bottom regular bulbs (their resistance would prevent flickering).
If you replace both the top and bottom bulbs with LEDs, I don't know whether there might be flickering (if there is, could be remedied with resistors), but check that the LEDs are bright enough.
I'm sure if you bought the good , expensive LED's they would be bright enough. I don't think using the LED's along with regular bulbs would look right,the middle light is LED and it has a different color than the others and it would be nice for them all to match. So a resistor is what a person needs to wire too?
I'd like to know if anyone has used the LED bulbs in either the top (Fog Light) or both top and bottom. If so, what LED bulbs did you use and where did you buy them? Was resistor required? Where do you attach the resistor? Pictures or a wiring diagram would be great. It may be a smart idea if one of the NAM Vendors offered a special Rear Brake Light/Fog Light LED KIT. I'm sure they would sell very well.
Several vendors offer a kit with a diode and "squeeze taps".
The LED draw about 10% of what the Incadescent does, so yes there is little added load on the BC1.
I used a 12 led in the fog light position.
http://user.mc.net/~jdewey/MINI/tail...osed_bulbs.jpg
As ADDED brake lights these were ok, particularly at night and directly behind the car.
http://user.mc.net/~jdewey/MINI/tail...e_straight.jpg
In the sunlight they are less impressive.
1157 LED were not bright enough for the main brake light position.
LED's have a very fast turn on time. When the car is first turned on the LED's flicker as the BC1 runs diagnostics. The regular bulbs don't flicker as they take more current and more time to turn on.
John
John
The MINI's reflector type of tail light housing is highly optimized to capture and reflect the light pattern from a regular bulb. For an LED replacement bulb, I would recommend the tower style on that superlumination page because it uses superflux LEDs (much brighter than the 3mm LEDs in the 32-LED bulb posted above), and would throw much more light into the reflector. However I still don't think it will be as bright as the original standard bulb.
Well I have done both modifications, the brake light mod and replaced the bulbs with LED's. Someone said something about flickering, and yes mine did develop a flicker on the passenger side brake light bulb (not the fog light), but placing a 1W 1k ohm resistor across to the ground cleared it right up. I replaced both bulbs (brake and fog) with the same LED bulb, the tower one that someone allready posted. I have noticed that the fog light is brighter than the brake light, probally because the fog light housing is smaller and focuses it better. Well I have had the brake light mod for 2 years and the LED's for 1 and no major problems with either. The other week however the diode came loose on one side and I lost the fog light. So instead of just wedging it into the connector I soldered that sucker in so no more intermitent brake lights, also warrenty for BC1... poof, gone.
Also there are pictures in my gallery, but they dont really do it justice, its better to comapre in person then in pictures.
This bulb, not so good. I bought this one first and I could barely see it during the day.
This one is better, I'd say about 93% as bright as regular bulbs
I am wondering how well this one works, there is fewer side LED's but it claims to be the brightest ever, bla bla bla. Someone should buy this one and try it.
