Electrical Coding for JCW Big Brakes
Old Apr 8, 2021 | 04:56 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Has anyone successfully coded their ABS/DSC module after installing JCW or aftermarket big brakes? I'm putting together a plan for upgrading the brakes on my Clubman, and I see the Mini has in their procedure for updating the software for "Retrofit Sport Brakes". I am trying to figure out if this can be done through NCS Expert / Dummy, without having to make a trip to the dealer.
Old Apr 28, 2021 | 09:28 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Bump? Anyone have experience coding for big brakes in NCS expert?
Old Apr 28, 2021 | 11:48 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
only done it with ista - d
Old Apr 28, 2021 | 11:54 AM
scotty_r56s's Avatar
scotty_r56s
I did it with Bimmergeeks Protool. If I recall correctly, I only had to modify the VO. When I get home this evening I'll take a look at it and try to find out what the option was.
Old Apr 28, 2021 | 11:56 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I only assumed I would have to sue NCS Expert to perform the coding. Would you be able to provide a guide for coding in ISTA?
Old Apr 28, 2021 | 11:57 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I appreciate the help. Even with the stock S brakes, the ABS is very touchy
Old Apr 28, 2021 | 01:09 PM
scotty_r56s
This is what was added to the VO. You'll need to code both the CAS and the FRM. If you are going to try it with ISTA, you'll need ISTD-P. For what it's worth, the Protool has totally replaced NCS Expert for me on the second Gen. They are still developing the first and third-gen, so the options are a little limited on those platforms.
Old Apr 28, 2021 | 01:22 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Blah, Bimmergeeks Protool looks like the easy option, but I do not have an Android device, and I would have to shell out $75 for yet another software package.
Old Apr 28, 2021 | 05:11 PM
scotty_r56s
I understand that. Just add the "SPBR" to the VO (both CAS and FRM) and you should be good to go. I don't recall changing the DSC module.
This can be done with NCS Expert.
Old Apr 29, 2021 | 09:43 AM
Yoshimura 1's Avatar
Yoshimura 1
I just look at this coding app it looks to be be pretty good.
Only saw video coding the BMW though but still looks great.
Old Apr 30, 2021 | 11:53 AM
Yoshimura 1
Can this app protool also be used on a laptop as well.
Old Apr 30, 2021 | 01:59 PM
scotty_r56s
Nope. The Protool can only be used on an Android phone or tablet.
Old Apr 30, 2021 | 08:18 PM
Yoshimura 1
Thanks for the reply
Old Aug 16, 2021 | 05:18 AM
texasmontego's Avatar
texasmontego
What does the change actually do to the car? Reduce ABS sensitivity? What happens is the programming change isn't performed?
Old Jul 10, 2024 | 05:02 PM
DogfaceSGM's Avatar
DogfaceSGM
Old thread but was wondering what you did?
I have been considering purchasing Protool. I have used NCS Expert and have Bimmercode/Bimmerlink. What's another app.
Old Jul 11, 2024 | 05:17 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I ended up at the dealer to get the JCW sport brake coding performed.
Old Jul 11, 2024 | 06:45 AM
DogfaceSGM's Avatar
DogfaceSGM
I am guessing the dealers charge about as much as the Protool App costs so I will go that route and have it for future use.
Old Jul 11, 2024 | 09:33 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The dealer here charged me an hours worth of labor.
Old Jul 11, 2024 | 10:16 AM
DogfaceSGM's Avatar
DogfaceSGM
So Protool both licenses (Diagnostic/Coding) is $160, I would guess one hour at the dealer is that or more now and the dealer is an hour away from me.
Old Jul 11, 2024 | 10:21 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Cool. If you have an Android device already, that would seem to be the better option. I have an iPhone, so I would have to also purchase a cheap android device to use the tool. For me, it was worth just hitting the dealer. I already have Carly for diagnostics and coding. Carly doesn't support the JCW sport brake kit option, however.
Old Jul 11, 2024 | 10:48 AM
DogfaceSGM's Avatar
DogfaceSGM
Yah, I don't do I-things. The other thing is if it is like BimmerLink/Code, I can load it on my Android head unit and have it with me all the time. I keep a USB to K+DCAN cable in my glove box. If a code pops up, I connect the cable and fire up Bimmerlink, find out what is up and either clear or correct the issue. I also have a good BT device but it works with Bimmer but not Torque Pro. I have a cheap ELM 327 that stays connected to a Y cable to run Torque. I can still connect my K+DCAN cable that way if needed. I also prefer to be wired when coding just in case if you know what I mean. I have an adapter for it also so I can connect to my phone or my tablet. It just gives me a bunch of options if I need it.
Old Jul 14, 2024 | 05:10 AM
DogfaceSGM's Avatar
DogfaceSGM
I did a try before you buy with Protool. Ended up going to their website and finding out you have to purchase their BT device (or a Thor brand Wifi). I have three OBD BT devices already (a cheap China ELM327 knock off, a Veepeak BLE+ and an OBDLink CX and none of them work with it. I understand the knock off, the other two are good products.
It does work with my K+DCAN cable but on their page it states it might not actually code with it and they recommend purchasing theirs. I think I am going to buy the app and try it with my cable. If it doesn't work, purchase a Thor adapter. At least it will work with some of my other apps.
Old Jul 14, 2024 | 08:39 PM
bluonyx's Avatar
bluonyx
Does this procedure have to be done if you have an "S" model and want to upgrade to JCW brakes?
Old Jul 15, 2024 | 05:19 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yes.
Old Jul 15, 2024 | 05:59 AM
DogfaceSGM's Avatar
DogfaceSGM
Some say they haven't but if you ever get into an "OH SH*T" moment and slam on the brakes and the ABS take over, it could cause more harm than good. Life is good and I like living it so my life is worth more than a couple hundred $$$.
(Also, it justifies me getting another tool, Bimmergeeks Protool, for my car.)
crazyworld
How to
22
Sep 6, 2016 01:53 PM
DoubleNick
Factory JCW Talk (2009+)
Aug 1, 2011 01:46 PM
D3m0N
Eastern Iowa MINIs
Nov 2, 2007 07:17 PM
alee
Tires, Wheels, & Brakes
May 17, 2005 02:50 PM
