Electrical powerfold mirror module
Old Feb 4, 2020 | 01:18 PM
user 73920's Avatar
user 73920
hi, where is the powerfold mirror module located exactly?
Old May 1, 2021 | 06:00 PM
jamez's Avatar
jamez
Left side of the car (driver side north america) under the inner door sill, just above the floor, about 10" towards the back of the car from the kick area fuse panel.
Old Mar 5, 2022 | 09:55 PM
cut7's Avatar
cut7
Do you have a picture? And does the car have the pigtail ready to plug into the power fold control unit?
Old Mar 5, 2022 | 10:10 PM
mountainhorse's Avatar
mountainhorse
Sounds like you are looking to Retrofit these on your car??
Have you seen these... maybe they can help with harnesses... as I don't believe the 'pigtail' is pre installed... at least not on my 2005 and 2006 cars here.
https://newministuff.com/power-foldi...-kit-534-p.asp
Old Mar 5, 2022 | 10:28 PM
cut7's Avatar
cut7
I already have the mirrors & the switch, & a complete R53 schematic. I just want to see where the factory put the control module. I'm real handy with wiring, so making my own harness isn't a problem. I was just wondering if the factory gave us the wires already. I have found that many vehicles come pre-wired for OEM accessories. It makes sense to make one harness for all cars, then plug in what the customer orders.
Old Mar 7, 2022 | 10:37 PM
mountainhorse
I'm with ya on that one.... The mini stuff listing kind of supports the notion of not plug play with module.... and no "Auto fold" without some serious work... but all is doable with effort I'm sure... a bit of coding and prudent wiring...Finding mating connectors can be daunting... but changing out the male/female connectors is not a big issue if the wires are there.
Reaching out to MINI stuff for some help may give you some good insights if they are open to help.
Good luck... keep us in the loop.
Old Mar 7, 2022 | 10:42 PM
cut7's Avatar
cut7
Are the R56 units electrically the same? I know they have different part numbers, & the R56 has mounting tabs cast into the plastic, but do they wire up the same? The reason I ask is because R56 units & pigtails are MUCH easier to come by.
Old Mar 7, 2022 | 10:43 PM
cut7's Avatar
cut7
Anybody have a wire schematic for the R56 folding mirrors circuit?
Old Mar 30, 2022 | 05:49 PM
mountainhorse
Any progress?
Old Mar 31, 2022 | 09:13 AM
cut7's Avatar
cut7
Any progress?
I've got all the parts, & studied both the R53 & R56 schematics. I think it will work. I just haven't had time to do it yet. I am going to test on the bench BEFORE I put them on my car. I don't think coding is required.
Old Apr 1, 2022 | 03:35 PM
mountainhorse
Did you find the solution to your project?
Old Apr 8, 2022 | 08:36 PM
mountainhorse
Can you post up those schematics and Parts list in this thread... would be a great resource for other to benefit from.
Old Apr 9, 2022 | 11:24 AM
cut7's Avatar
cut7
Here are the schematics for the R53, R56 (LHD), & R56 (RHD). The circuits are similar, & I believe the R56 control box will work. I will test this out on my bench & report my findings; however, I am optimistic about the outcome. The yellow/green wire that attaches to the navigation system also goes to the ABS/DSC (I've included the ABS/DSC schematic for clarity on this point). I believe this is speed output to prevent the mirrors from folding whilst driving. The R56 module uses two power leads & two grounds, whereas the R53 unit uses only one of each. This is not a big deal, you can tie the two leads together. Just make sure you pull power from a non-switched source, that way the mirrors will continue to fold even after you remove the key. Both modules use pin 12 as the trigger wire going to the mirror adjustment switch, but the lead is a different color; I would use the proper color for your vehicle to avoid confusion for future owners; i.e. blue/violet for R53, yellow/red for R56 cars.
You will need folding mirrors (obviously), control module 61.35.9.177.975 (this is the R56 module, it has mounting tabs, vs. clipping into a plastic holder on the earlier cars), the pigtail to attach wires to said module, & a mirror switch with the folding button; I believe the part number for this is 61.31.6.918.216. I don't think any coding is required for this mod.
Below is a picture for clarity.
Hope this helps!
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Apr 10, 2022 | 10:11 PM
mountainhorse
Awesome...thank you for including us in on your adventure with this project!
Looking forward to your successful finish !
Old Apr 12, 2022 | 09:33 AM
Eric_Rowland's Avatar
Eric_Rowland
Looks intriguing. I installed the newministuff kit years ago, but like the idea of an OEM solution. Love the power fold.
Old Apr 12, 2022 | 09:37 AM
cut7's Avatar
cut7
I went to look at your folding mirror thread, but there's no pics. Can you please fix the links so we can view them? I would love to see what you've got!
Old Apr 23, 2022 | 06:12 PM
Eric_Rowland
You can see all the pics in my albums.
This was an aftermarket kit, so no OEM button or auto-fold.
nicknack
Electrical
Dec 27, 2017 06:32 AM
ti22fjc
Aug 17, 2013 09:36 PM
JT///MC
Aug 16, 2011 08:40 PM
kelvin88
Electrical
May 23, 2011 12:00 PM
woody30028
Mar 10, 2011 02:39 PM
