Electrical Guage question
Old Feb 27, 2016 | 08:09 PM
AFN704's Avatar
AFN704
Guage question
Looking into getting some extra guages. I want air fuel ratio, boost pressure, and I guess oil and water temp guages. Going for a manic stage 2 tune and want to be able to make sure my car is running safely. What are some good cost effective reliable guages. Also approximately how much will the install cost? Thanks for the help!
Old Feb 28, 2016 | 12:24 AM
Mister's Avatar
Mister
I have a ProSport premium boost gauge w/ Alta gauge mount. The gauge is noisy, but works well and looks great imo. They make everything you mentioned, except the a/f.
http://prosportgauges.com/60mm-premium-amber-white.aspx
I'm not sure about the install cost. I installed mine myself w/ thanks 100% to the write-up that Alta did.
Old Feb 28, 2016 | 06:43 AM
cerenkov's Avatar
cerenkov
The most cost effective is scangauge2 but you can also go the smart phone with dash command or torque app and a wifi/Bluetooth obd2 adapter.
Old Feb 28, 2016 | 08:26 AM
SpuuDy's Avatar
SpuuDy
I agree with cernkov, how ever mechanical gauges are more accurate. I bought my boost gauge from autozone . The brand is equus and cost like 40 bucks but you get what you pay for
Old Feb 28, 2016 | 02:47 PM
adolphrettmer's Avatar
adolphrettmer
I installed the P3 gauge about 2 months ago. Very easy to read and covers just about everything that you need. A little costly but installs in less then 1/2 hour and looks great.
Old Feb 28, 2016 | 05:11 PM
AFN704's Avatar
AFN704
Could you post a link to where you got it. I'm curious what guages you guys think I need. I want to have the information I need to make sure my car is within safe parameters. What is a good Bluetooth obd2 scan tool and how much less accurate are they. Will is show afr
Old Feb 28, 2016 | 05:26 PM
cerenkov's Avatar
cerenkov
I question the comment about mechanical gauges being more accurate. I would trust the sensors that are already installed in the car. They are the same ones that the cars computers use.
Old Feb 29, 2016 | 05:19 AM
adolphrettmer
The P3 gauge is sold by many of the aftermarket suppliers that post on this site. They are not cheap but cheaper then purchasing the factory setup. I tried the Scan gauge 2 but the font is too small for my eyes. The P3 is perfect as i had one in my VW GTI for quite a few years.
Old Feb 29, 2016 | 05:26 AM
thebombardier's Avatar
thebombardier
As much as I'd like to believe that, with a bluetooth OBDII and Torque app I was getting a peak boost reading of 24 PSI. If I've read around correctly peak boost even with a Manic tune should be ~20.
Old Feb 29, 2016 | 07:32 AM
cerenkov's Avatar
cerenkov
Is that an instantaneous peak value? The quoted boost levels for the manic tune are steady-state. You need to data log and graph the boost levels to really see what is going on. Using Dashcommand, I'll see peak values of ~22 psi but the steady-state values are lower.
With a mechanical gauge that measures pressure directly with a tube connected to the manifold you will have pressure losses in the tube and fittings which may need to be accounted for depending on their magnitudes. The one nice thing about a mechanical gauge is that they tend to be self-dampening so the instantaneous peaks are automatically "filtered" out.
Old Mar 2, 2016 | 12:22 PM
+1 on the p3cars gauges, reads and clears codes, plug and play, digital ( very fast ). Fits into the dash, by the tach.
http://www.ecstuning.com/Search/SiteSearch/P3M58L/
Old Mar 2, 2016 | 06:13 PM
AFN704's Avatar
AFN704
I looked it up and that is really cool. One of the main reasons that i need it though is for the AFR. From some of the videos that i watched i didn't see that function like i did in the Scan Gauge 2. Is it possible. I like that one a lot more although the Scan Gauge 2 shows more at once.
aquamann
Apr 24, 2018 12:11 PM
MINIMIKO
Feb 24, 2016 08:46 AM
azbawood
Feb 10, 2016 12:41 PM
thereisnosubstitute
Feb 10, 2016 11:47 AM
MarioKart
Jan 29, 2016 04:14 PM
