Electrical NCSExpert: MINI Connected, Audio Playback with iPhone 5 and up via Front USB
I can't remember if i've posted this or not but I thought it would be worth it since this saves a ton of us newer iPhone owners a TON of money on a cable we don't need from MINI to get MINI Connected and USB Audio from our iPhone's with Lightning ports working (iPhone 5/5S/6/6S and Plus).
REQUIREMENTS:
-MINI Connected in your MINI, may also work with just normal radio/headunits too. I have MINI Connected and HK sound.
-NCSExpert and basic skills
-OBD II cable
ISSUE: Connecting a lightning cable to front USB port on an R56/R58/R59/R60 shows iPhone but does not playback audio. Dealer will say you need their special Y cable; I have purchased several and none work still. The newer late 2015 version of MINI Connected may work.
RESOLUTION:
-Use NCSExpert and read your MEDIA module
-Find this entry:
USB1_IPOD_AUDIO
analog
and change the analog to digital so it is:
USB1_IPOD_AUDIO
digital
Recode the MEDIA file back with the option we changed and bam! You should be able to finally use just the standard Lightning sync cable with your iPhone and MINI to playback, charge and use mini connected via the factory cable.
Verified working on my 2013 R58 and iPhone 5S and iPhone 6Plus.
REQUIREMENTS:
-OBD II cable
RESOLUTION:
-Find this entry:
USB1_IPOD_AUDIO
analog
USB1_IPOD_AUDIO
digital
Please report back as soon as you find out if this works with non-Mini Connect. My Lightning adapter from has finally given out, even after I wrapped it with shrink tubing. I refuse to buy another, as this one was replaced by at the store. Right now I'm using a 30pin to bluetooth adapter for music, but I would love to be able to use a lightning/usb cable to keep the phone charging as well.
People (like myself) that do NOT have MINI Connected do not have the MEDIA module. We have the 2RAD module and you cannot connect to this via NCS Expert (at least I haven't been able too).
Thank you
Question:
I just ordered the cable and will be in process of starting to recode stuff in a couple weekends, but the big question I have is about this particular mod. Does the USB charge your iPhone 6?
Also, by switching to digital does it allow any video signal to come through? Apparently the 30pin old phones did, and everyone is of mind that the lightning doesn't carry a video signal. Just wanted to confirm that's still the case after changing the audio input code from analog to digital.
Thanks.
Thanks.
USB charging works fine! :)
Question:
Thanks.
Thanks.
Working with iphone 7, but no longer since ios 11.1.1
Hey everyone,
Old thread but still useful so digging it up.
Confirms this works in 2017 with an iphone 7 connected via USB on a mini r56/r57. After coding, sound quality over USB is dramatically increased, and the spotify / mini connected integration allows to search your library easily and safely through the nav ****.
Great hack.
However since ios 11.1.1, no usb detection (iphone says device is not recognized and iphone doesnt show up in mini menu). Has anyone faced a similar issue and/or has resolution ? Cheers
Great hack.
Hey everyone,
Great hack.
Great hack.
stierzy34
Apr 9, 2016 02:25 PM
Navigation & Audio iPhone connection without Wired upgrade?
DevilMini
Dec 3, 2015 07:22 AM
Eric (Plug Guy)
Nov 24, 2015 02:53 PM
