Electrical Brake wear indicator
Old Sep 2, 2012 | 05:32 PM
purplehaze05mcs's Avatar
purplehaze05mcs
Light went on. Replaced rotors, pads and wear indicators. Light still on. Went out the next morning but came on again after a few miles. Does it need reset? I thought they're suppose to go away after replacing indicators. Help!!! It keeps on staring at me.
Old Sep 3, 2012 | 07:02 AM
yetti96's Avatar
yetti96
You need to reset the OBC. Did you do a search on here for resetting the brake sensor? That's how I did mine
Old Sep 3, 2012 | 11:21 AM
purplehaze05mcs
Is that the thingy were you hold down the odometer **** while turning on the ignition? Ok I did that one five years ago for something else. I thought I can just use a reset tool. Thanks for the info.
Old Sep 6, 2012 | 10:00 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Did resetting the OBC work out?
888.280.7799 | 6am - 5pm PST
Old Sep 6, 2012 | 06:56 PM
purplehaze05mcs
Could not find my copy of the proceedure. Went to minimania and could not find it on their site. Maybe someone will send me the link to it. Thanks for checking on the outcome.
Old Sep 7, 2012 | 09:56 AM
PelicanParts.com
Vendor
After a quick search, we found this: The MINI uses a Brake Wear Sensor on the front left and rear right brake pads. When the brake pad wears down, the brake pad wear sensor is also worn down and will eventually trigger the warning light to alert you. Once the warning light is triggered, the wear sensor needs to be replaced. After replacing the sensor, turn the ignition key to the #2 position for around 30 seconds without turning over the engine...the light goes out."
-https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/125534-resetting-brake-pad-sensor-light-how.html
Old Sep 8, 2012 | 01:35 PM
purplehaze05mcs
I did the 30+ wait before start up and the light went out. After a couple of miles it went on again. Tried it again before start up but it did the same. I'm wondering if the lenghty procedure will work permanently. Still looking for that info. =(
Old Sep 8, 2012 | 01:43 PM
daflake's Avatar
daflake
Check your sensors and make sure you didn't nick one. If you did, the light will come back on. There is nothing one the first gen that has to be reset, just what you have done. The above information by Yetti is incorrect.
Old Sep 8, 2012 | 02:10 PM
Capt_bj's Avatar
Capt_bj
Saying the same thing as daflake.....
It looks to me like you either damaged a sensor - the wires are really really thin - or it is not plugged in correctly. Either way the car is still seeing an "open circuit" just as it would for a worn sensor. Everytime you reset it, it looks and sees "open" aka "worn"
hopefully you did not do front and rear in one session. 'cuz if you did finding the source is gonna be harder. If you just did, say the fronts, then you know the problem is isolated to that sensor. I think the darn things are worthless so I just short them out. Or short them IN maybe!
FIRST - triple check the connector for the replacement sensor . . . make sure it was clean and tight.
If this doesn't work then
I'd try to cut out the sensor, snip the wires going to the sensor (you might get away with reusing the OLD sensor for this, basicaly build a jumper to fool the system for a test)
then tie the two ends together and zip-tie the wire someplace safe, then try the reset.
if you did front and back at the same time ... sorry, now you know why I do fronts, then drive for two weeks, then do rear (on the rare occasion I need both ends at the same time)
Old Sep 11, 2012 | 08:22 AM
PelicanParts.com
Vendor
FWIW: https://www.northamericanmotoring.co...tor-light.html
Gremothra
Sep 9, 2015 08:42 PM
wildwestrider
Sep 4, 2015 06:25 AM
squawSkiBum
Sep 2, 2015 09:56 PM
Ntety
Sep 2, 2015 08:39 PM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
