Electrical Defi wiring help please.
Old Sep 10, 2012 | 12:40 PM
jwconnexion's Avatar
jwconnexion
update: found speed signal tap point *reference
update: got it working except Speed signal wire.. so unit is registering rpm but need Speed signal(miles/h). any thoughts?
Recently purchased Defi zd csp and need help with wiring.
+Defi control unit
1. Red: +B(Battery: to 12v battery wire)
2. Orange: IGN(Ignition: to 12v wire while ignition is on)
3. Black: GND(ground)
4. White: +ILM(Illumination: to 12v wire small light is on)
+Defi ZD unit
5. Green wire: for Tach (rpm)
6. Blue wire: for Speed (miles/h)
2006 r53 jcw
1. Red w/ blue tracer w/ yellow hatchers (obd2)
2. Green w/ blue tracer w/ yellow hatches (under steering wheel column)
3. Brown
4. Grey wire with red tracer (tach wire)
5. White with red tracer (obd2)
6. ??
reference
http://www.defi-shop.com/media/zd_manual_1202-1_e.pdf
http://www.defi-shop.com/media/acu_manual_1112-1_e.pdf
http://www.altaperformance.com/share...ampinr205b.pdf
http://www.fes-auto.com/products_detail.php?productid=6 *Speed signal tap point illustrated
Thanks guys!
Old Sep 12, 2012 | 11:22 AM
ERIK06MCS's Avatar
ERIK06MCS
Im confused, you said you need tach signal but then again put in parenthesis miles/hr. Tach is revolutions per minute. Crank sensor is located on front of the block. Not sure about ecu pin location. Some triggers use signal from coil as well as coil is triggered in repetition matching crank speeds.
Cant figure out though if you are looking for rpms or speedo signal mph.
Post pics when complete if you can, Im intrigued by these things.
Old Sep 12, 2012 | 11:24 AM
ERIK06MCS's Avatar
ERIK06MCS
Also, look for wiring info for the shift light people mount to the steering console right below the dash. Not sure if the shift light is a jcw or aftermarket part but it would also operate off a tach signal. Wiring could be similar to what you're looking for.
Old Sep 12, 2012 | 12:36 PM
jwconnexion
Thanks for the input Erik06mcs!
Fellow namer helped me with locating speed signal tap point.
Originally Posted by rkw
The installation instructions for the FES Shift Light describes both wires. Download the Users Manual on this page: http://www.fes-auto.com/products_detail.php?productid=6
For some reason defis Green wire(speed) had to be taped to jcw tach wire (obd2 pin9). Now I am trying to figure out where this yellow w/green tracer wire leads near steering column for clean/easier install. Any thoughts?
I will post some pics later this afternoon.
OutMotoring
Mar 3, 2017 06:29 AM
SJ-R50
Oct 28, 2015 08:39 AM
eMINI of the State
Oct 2, 2015 03:12 PM
FatherG
Sep 29, 2015 02:47 PM
dragonby
Sep 25, 2015 08:10 PM
