Electrical R53 NCS Expert Guide Add-In
Old Nov 16, 2021 | 07:19 PM
  #126
shrevemini's Avatar
shrevemini
Top Answer: 1
Originally Posted by jagster936
I just did that. Same message. It's a windows 10 64 bit laptop, I suspect has to do with 64 bit part, maybe the old software is 32 bit.
Mine is on windows 10. 64 bit.
Old Nov 16, 2021 | 07:22 PM
  #127
jagster936's Avatar
jagster936
Did you install the version linked at the beginning of this thread? Or another version? We can private message or some other thing to avoid spamming everyone, I will post whatever works when I get it to
Old Nov 16, 2021 | 07:29 PM
  #128
jagster936's Avatar
jagster936
Oh - You have exceeded your private message storage quota hahaha
Old Nov 16, 2021 | 07:33 PM
  #129
shrevemini's Avatar
shrevemini
Top Answer: 1
Lol. Let me empty it. To answer your question. No I use a different one.
Old Nov 16, 2021 | 07:39 PM
  #130
shrevemini's Avatar
shrevemini
Top Answer: 1
When I do remote install. I downloaded
Inpa
Ncs expert
Ncs expert for dummy
Win kfp
Updated daten files
Old Nov 16, 2021 | 07:41 PM
  #131
jagster936's Avatar
jagster936
The problem is there are many different versions of this. I'm trying to find a set that works with my R53 2005 MCS. His above link does not work and the updated version I had from bcables installer does not work, though it connects just says invalid VIN. Common error.
What versions did you install? And what profile did you use in NCS Expert
Old Nov 16, 2021 | 07:44 PM
  #132
shrevemini's Avatar
shrevemini
Top Answer: 1
The issue is when some folks install inpa. They are missing mini cooper r50/r53 option to select. You have to go I to configdat file an do some messing around to add this to your options.
With ncs expert I use revtor.
Old Nov 16, 2021 | 07:46 PM
  #133
jagster936's Avatar
jagster936
Interesting, I never saw that option. I sent you message to avoid spamming this thread until I resolve this
Old Nov 16, 2021 | 09:06 PM
  #134
shrevemini's Avatar
shrevemini
Top Answer: 1
If anyone needs help installing inpa an ncs expert. Type here. Or try to send me a message, lol.
Old Nov 16, 2021 | 09:21 PM
  #135
jagster936's Avatar
jagster936
Yea Shrevemini was a real help, I cannot reproduce what he did fully on here. He needs to write a guide
That being said, now I'm getting CHASSIS is faulty when select F3 in NCS expert, hmm?
Old Nov 16, 2021 | 09:23 PM
  #136
shrevemini's Avatar
shrevemini
Top Answer: 1
chassis fault?
hmm let me look into it for you.
Old Nov 16, 2021 | 09:28 PM
  #137
jagster936's Avatar
jagster936
Yea if I click F3 after loading profile and clicking F1, then it says Chassis if Faulty. If I click OK then click F3 again it says
ZCS-ECU Error:
COAPI-1020: Datei konnte nicht zum Lesen geoeffnet werden C:\NCSexper\daten\r50\r50sgfam.dat
German clues?
Old Nov 16, 2021 | 09:30 PM
  #138
jagster936's Avatar
jagster936
File could not be opened for reading. There is no R50 folder there at all, do I need to add it from the first post or do you have a more updated set?
Old Nov 16, 2021 | 09:35 PM
  #139
jagster936's Avatar
jagster936
I copied the r50 Daten files / folder into that directory and getting the good ole vin is faulty message. These were the files from the top of this thread
Old Nov 16, 2021 | 09:39 PM
  #140
jagster936's Avatar
jagster936
Ok, crazy software. It gave that error. I exited and tried again I think it read it. Gave some other message let me mess with it some more
Old Nov 16, 2021 | 09:43 PM
  #141
shrevemini's Avatar
shrevemini
Top Answer: 1
Any luck?
Old Nov 16, 2021 | 09:44 PM
  #142
jagster936's Avatar
jagster936
I got it! I had a typo in the .man file. I will mess with this some more thank you so much! Where is the NETTODAT.TRC file the guide says to save? Don't see that one
Old Nov 16, 2021 | 09:46 PM
  #143
shrevemini's Avatar
shrevemini
Top Answer: 1
It been a while since I messed with ncs expert. I would search YouTube. That's where I figured out how to screw around in ncs expert.
Old Nov 16, 2021 | 09:51 PM
  #144
jagster936's Avatar
jagster936
Gosh I hate youtube it's so slow. I love forums because can skim and glance around. I'll see what I can find thanks.
This would take some time to test but couldn't you just copy all the folders/programs directly onto another win10 laptop to have all the correct files for this to work? I think that BMW coding tools program you used just updated these files. I'm sure it's more complex than that but perhaps not. Just an idea
Old Nov 16, 2021 | 09:54 PM
  #145
shrevemini's Avatar
shrevemini
Top Answer: 1
Correct it is used to update the files. Just makes it much easier than farting around in each folder trying to figure out where everything goes 🤔.
Old Nov 16, 2021 | 10:27 PM
  #146
jagster936's Avatar
jagster936
I don't understand how to get the NETTODAT.TRC file created. I created NETTODAT.MAN and it still didn't appear when I read the FSW_PSW_TRC. I've been googling around having had much luck, anyone know how to do this? Like always most forums just assume you know how to get it already or have it. I just want to back it up for the BC1 module as instructed in the writeup
Old Nov 16, 2021 | 10:32 PM
  #147
jagster936's Avatar
jagster936
Everywhere I see just says read the module you want and NETTODAT.TRC is created. It is NOT in my case.
Old Nov 16, 2021 | 10:44 PM
  #148
shrevemini's Avatar
shrevemini
Top Answer: 1
Try watching this vid
Old Nov 16, 2021 | 11:00 PM
  #149
jagster936's Avatar
jagster936
Wow that has a wealth of info. I looked at the the part about reading he uses execute job instead of read ECU. I will try that tomorrow, weak human needs sleep . Thank you for all the help
Old Nov 16, 2021 | 11:01 PM
  #150
shrevemini's Avatar
shrevemini
Top Answer: 1
No problem.
