Electrical 12v add-on
Old May 12, 2012 | 07:33 PM
deanmosh's Avatar
deanmosh
12v add-on
Hi All,
I have searched and read all about adding an additional 12v socket. I understand how it works, but it seems all the links are dead--the ones that show which add-a-circuit to use.
I bought this off amazon,
http://www.amazon.com/Littelfuse-FHA.../dp/B0002BGELQ
But I got the piece and it says it is only to be used for anything lower than 10 amp. But I see that the cigarette lighter fuse is a 15? Is 15 a different number that doesn't refer to amps?
Will it be okay if I just use this product?
Thanks in advance!
Old May 12, 2012 | 07:50 PM
Blackbomber's Avatar
Blackbomber
What do you plan on plugging into it?
Old May 12, 2012 | 07:54 PM
deanmosh's Avatar
deanmosh
I plan to just use the original one for a cigarette lighter and sometimes ipod/iphone, and the other one for iphone/ipod only.
Any advice?
Old May 13, 2012 | 02:44 AM
HRM's Avatar
HRM
You will be fine.
Old May 13, 2012 | 07:53 AM
ZippyNH's Avatar
ZippyNH
Volts x amps= watts....so 12volts times 15 or even 10 amps....=120watts to more at the higher limit...so no issues for most any common item plugged into a car...even the 12 electric coolers are desgined for this type of use....portable inverters are a different issue....it is common to see 200 watt cirgette plug inverters...those are ok...but have seen ones labeled 400 watts or even 800 with a cirgette plug...those REQUIRE a battery connection to get the higher amps needed.
Old May 13, 2012 | 07:55 AM
ZippyNH's Avatar
ZippyNH
PS
If you check the fuse (usually glass in most car adaptors), they are often only 2.5 amps, sometimes 5, and even that is overkill....a cell phone for exampe draws (almost always) LESS THAN ONE AMP.
Old May 15, 2012 | 11:47 AM
deanmosh's Avatar
deanmosh
thanks everyone for the replies and the help. looking forward to doing this!
Old Jun 3, 2012 | 05:43 PM
Duncan1800's Avatar
Duncan1800
Semi-related, so I figured I'd post it here.
Just got my '04 Cooper yesterday, and have the XM radio receiver and antenna from my old car ready to go. However, plugging the 12V power adapter into the socket behind the cupholders seems not to work. The cigarette lighter itself works fine - push the button down, it pops up nice and toasty when it's done - but it doesn't seem to "recognize" my XM adapter.
Any thoughts?
Duncan :D
Old Jun 18, 2012 | 07:38 PM
Duncan1800's Avatar
Duncan1800
Update: Have figured out, by noticing the flicker of the socket's orange "glow ring", that it's probably the wiring underneath having a problem. The socket itself wants to pull out of the console every time I try to attach something. Will have to dig into the console this week and see if I can cinch things back together.
Any thoughts?
Old Jun 19, 2012 | 06:46 AM
JumpingJackFlash's Avatar
JumpingJackFlash
If you choose to tap into the wiring directly, keep in mind that not all plug-in electronics operate on 12 volts. I wanted to splice in the wiring for my Sirius Sportster 5 satellite radio, but I found out the unit operates at 5 volts. So I bought a lighter socket extension cord, cut off the female end, and spliced it into the original wiring underneath the center console. Then I tucked the extension and the original radio lighter plug inside the right radio support tube.
Old Jun 19, 2012 | 05:40 PM
Duncan1800's Avatar
Duncan1800
Oh, no worries about splicing or tapping straight in. I'm just planning to get the socket working cleanly first so I can plug in the standard adapter. But I do like your idea of the "hidden" socket, too - the 12V adapter on my Audiovox XM receiver is fairly massive, and it would be nice to hide that while opening up the standard socket for other purposes (phone, air compressor, etc.).
I was also thinking of getting the '05-up under-console tray from OutMotoring anyway - with a remote socket, that might hold both the adapter and the radio with some finagling.
Filmy
15
Jun 6, 2023 06:27 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 14, 2015 04:19 PM
laf04mcs
Sep 13, 2015 04:41 PM
Puggles
Sep 11, 2015 11:53 AM
