Electrical Gauge Wiring Help.
Old Nov 3, 2010 | 08:28 PM
fensty245's Avatar
fensty245
Gauge Wiring Help.
Okay so I got my new gauges in the mail and im going to be putting them in tomorrow or friday. Now I already have some gauges wired up so I will be using the existing wiring just adding some. The gauges I bought now go from white to amber when you turn the lights on. It says i need to tap into a wire for the parking lights. Which wire do you guys suggest to tap into? I want it to be easy to get at. Thanks!
Old Nov 3, 2010 | 08:29 PM
fensty245's Avatar
fensty245
Oh and also, I have my current gauges run off add-a-circuits. Which spots in the fuse box do you recomend for constat power and ignition power. thanks again.
Old Nov 3, 2010 | 08:31 PM
JIMINNI's Avatar
JIMINNI
What kind of gauges did you buy?
Old Nov 3, 2010 | 09:04 PM
fensty245's Avatar
fensty245
prosport
Old Nov 4, 2010 | 07:05 AM
Mini SUV's Avatar
Mini SUV
I would use ignition power to run your new gages. What type of Prosport gages did you get?
Old Nov 4, 2010 | 09:03 PM
fensty245's Avatar
fensty245
The white/amber ones. So your saying for me to ditch the add a circuits?
Old Nov 5, 2010 | 05:59 AM
Mini SUV's Avatar
Mini SUV
No, I like "add a circuit". Another gage /gage light or two added will be OK on the same fuse as the other gages you added (they don't take much current). I would place the "add a circuit" to wherever it fits best for access and add to a lower amp fuse spot. The current to the base fuse panel should be the same only seperated by constat power and ignition power spots.
Old Nov 5, 2010 | 06:24 AM
fensty245's Avatar
fensty245
Im going to buy another add a circuit to use for the headlight switched power to switch them from white to amber. Ill post up my results later. The only problem I noticed is, sometimes when you use the add a circuit it changed the fuse slot from ignition voltage to constant power
Old Nov 5, 2010 | 10:00 AM
Mini SUV's Avatar
Mini SUV
I don't know how that could be if the "add a circuit" is plugged into the same original fuse slot.
Old Nov 5, 2010 | 11:14 AM
fensty245's Avatar
fensty245
I've read on here about other people h theaving same issue. Since I can't find a fuse that will change the gauges from white to amber I might just run a single wire and tap into my parking lights so they will change. Ill post my results here!
molala
Oct 2, 2015 01:53 PM
minimofo
Sep 30, 2015 12:26 AM
Filmy
Sep 7, 2015 08:27 PM
Gen1Parts
Sep 7, 2015 01:37 PM
mikeandtricie
Sep 4, 2015 01:42 PM
