Electrical need to permanently disconnect all airbags in r53
Old Oct 27, 2010 | 10:21 AM
pimpedout97x's Avatar
pimpedout97x
I cant physically pull out the curtain bags becuase of my stereo. not sure if i can even get to the plugs if its in the rear where the box is.
anyways, i want ALL airbags permanently disabled. the dash ones, curtain, pillars, seats, etc.
do i just need to pull the SRS fuse or what?
Old Oct 30, 2010 | 01:41 PM
chris.j.lamb's Avatar
chris.j.lamb
Remove the airbag ECU under the console
Old Oct 30, 2010 | 03:31 PM
pimpedout97x
thanks for the info!
Old Nov 6, 2010 | 04:44 PM
wokkie001's Avatar
wokkie001
Hi
I am very interested in your solution to disable them all.
Does this resolve the problem with the dashboard light for the airbag/
if so, where is the ECU located that I have to remove?
Please explain it simple, I am a newbie with this stuff
Old Nov 13, 2010 | 05:17 PM
pimpedout97x
is this it?
Old Nov 14, 2010 | 05:59 PM
pimpedout97x
bump.. need to know asap,,, trying to remove the whole dash, and i wanna take the airbag out, but i wanna make sure the ENTIRE SRS system is DISABLED for good, before i continue...
Old Nov 14, 2010 | 06:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Originally Posted by pimpedout97x
is this it?
No that is the DSC lateral G sensor.
The airbag module is under the carpet under the ebrake handle. It is held down with 10mm nuts.
Old Nov 14, 2010 | 07:21 PM
rkw's Avatar
rkw
Wouldn't it be easier to simply pull the fuse? Wiring diagrams show the airbag module using F18.
Old Nov 14, 2010 | 07:37 PM
WayMotorWorks
Vendor
I wouldn't trust that removing one fuse would disable the system.
Old Nov 14, 2010 | 07:42 PM
pimpedout97x
yea, same here
thanks for telling me it was under the carpet, ill dig it out tomorow!
i normally wouldnt disconnect the airbags, buts its clearly not a daily driver, hardly EVER gets driven, so i dont mind not having airbags.
so by pulling this ecu out/disconnecting it, itll disable every airbag correct? will the airbag light be disabled as well, or will that still light up? (i dont care, just wondering, lol)
Old Nov 14, 2010 | 07:45 PM
pimpedout97x
btw, what is that?
Old Nov 14, 2010 | 08:18 PM
WayMotorWorks
Vendor
Yes when you take out the airbag module and disconnect it's ground the airbags will be disabled, and the airbag light will be disabled too.
As for the G sensor, it's for the traction control to determine the lateral acceleration of the car to activate the traction control if needed.
Old Nov 15, 2010 | 04:12 AM
pimpedout97x
gotcha. thanks for the clarification.
Old Nov 16, 2010 | 04:21 AM
pimpedout97x
Peek-a-boo.
Success! No airbag light anymore.
Old Nov 16, 2010 | 05:55 PM
pimpedout97x
ok so Glen told me there is still a charge in the airbags even though the ECU is disconnected. That means they can still go off?
Old Nov 17, 2010 | 01:18 AM
Walnuts's Avatar
Walnuts
Just finish your wall build man, if you remove the ecu it removes all the sensors needed to actually set the bags off. I've been following that build thread on car audio years before I even had a mini lol
Old Nov 17, 2010 | 05:05 AM
pimpedout97x
lmao i know, its not my daily driver so its just been sitting, dont really have much time to work on this car much anymore
Old Nov 18, 2010 | 09:59 AM
chris.j.lamb
NO
Old Jul 25, 2014 | 08:44 AM
0004BES's Avatar
0004BES
Bump.
Does this still turn on the airbag light on start-up? Then it goes off? Or does it not come on at all?
trw92a
Aug 26, 2015 01:47 PM
madmaxxed
Aug 24, 2015 11:56 PM
one73ronin
Aug 19, 2015 12:36 PM
DWooderson
Aug 10, 2015 09:12 AM
quality_sound
Aug 7, 2015 09:36 AM
