Electrical Close Windows & Sunroof with the remote, yes you can
What version of datens are you running and what version of INPA & EDIABAS are you running? When I updated to v40 datens I had to also update EDIABAS to v7.2.0 to stop getting errors. It doesn't sound like the error you have as I was able to get my VIN and such (I believe that's the step you are on). My error popped up when I hit "back" after that step.
Is INPA running ok? i.e. both circles are black? You have to leave the INPA server running. Just something else to check.
Sorry you are having this issue. From a quick bit of research it is mostly likely related to the newness of your vehicle. Looks like updating your Datens to a more modern version will be necessary. Search for that error message on the Diagnostic forums (without the number), I found a bunch of threads like this one:
http://forums.bimmerforums.com/forum...invalid+for+FA
Ah somehow I missed the most recent posts, the version of EDIABAS could be an issue, too. I found some posts referring to needing to upgrade the EDIABAS in order to read MOST bus modules like the ULF, I really want to try that myself as I haven't ever been able to access it with NCS (but of course DIS can read it fine and that is using the same version of EDIABAS).
Trouble reading FRM2
I have successfully modified CAS so I can close the windows and sunroof from the fob, SHD so I have two-touch operation of the sunroof, and IHKA to disable automatic engagement of a/c when pressing auto button.
I would like to modify FRM2 for the auto-up not interrupted when opening a door and possibly the fogs and high beams on simultaneously, but I can't seem to read FRM2. If I go "Select Module", I don't see FRM2 as a choice, I see FRM. If I select that, the dialog box makes it look like it will be FRM2, but when I try to read it, I get an error message, and the trace file is very large -- like 117KB. I'm using V40 datens now but had the same problem on a previous install using V38.
Also, has anybody actually found the setting in CHAMP for the weatherband? My module list only shows HAMP, and if I read it, it just has a list of chassis IDs. It doesn't have any settings to change.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
https://www.northamericanmotoring.co...-2011-r56.html
Are you getting a Faulty BEST version error? If so check out my thread. Basically you need to update EDIABAS to the newest version and FRM works like a charm; not sure about FRM2 though since i never had to go in there.
I followed the directions to update EDIABAS, and was able to read FRM. Now I have some questions. I want to set the options to 1) not interrupt window roll up when the door is opened and 2) allow the fogs and high beams to be on simultaneously. In the spreadsheet, these are listed as
1) FRM2: TUERAUF_STOP_MAUT (activ -> nicht_activ)
2) FRM2: FL_UND_NSW_NICHTGLEICHZ (activ -> nicht_activ)
So, when I press F4 to select the module to read, there is a FRM not a FRM2. When I select that module, the dialog box says:
ECU short FRM
CBD name: FRM2_R56.C08
CABD name: A_PL2FRX.IPO
SGBD name: FRM_70.PRG
So, is this FRM or FRM2 or what?
I read that module and it looks like it has the right stuff in it. I changed FL_UND_NSW_NICHTGLEICHZ to nicht_activ. However, there is not a TUERAUF_STOP_MAUT, but there is a FH_TUERAUF_STOP_MAUT_3R.
I decided to give those changes a try, so I coded both of these values and wrote the module back to the car. Neither change seems to have any affect. The auto-up for the windows still stops if I open the door, and the fog lights still turn off when I switch on the high beams.
I tried reading the module again to make sure the update was written. The values were in fact written, and the newly read data has some additional values that were not in the data when I read it the first time, these values are:
CBD_ZEICHN_INDEX - wert_01
INNENLICHT_ABSENKEN - wert_05
TIME_COLOR_CIRCLE - 5sec
Google Translate says:
ZEICHN = Draw
INNENLICHT ABSENKEN = Lower Inner Light
wert = worth
So coding experts, here are my questions:
Thanks in advance.
ECU short FRM
ZEICHN = Draw
wert = worth
- Am I working with the right module?
- Why does the name for that parameter not match?
- Why don't the changes have any affect?
- Where did the new values come from?
Thanks in advance.
There is absolutely nothing intuitive about downloading, installing or using the software necessary to code your car. I am a software engineer by profession and have no fear about getting down into the bits and bytes, but I spent several weeks studying the various online guides and spreadsheets before I felt comfortable trying to code some modifications into my MINI. I still can't get a couple mods in the FRM module to work as you've seen in my previous posts. No offense, but if you need intuitive and easy to use software, then coding is definitely not for you.
Great to see this section still alive and active. It's been awhile since I've done any coding and it looks like a lot more discoveries have been made. I don't have auto up windows in my 2007 so I think it's time to dig out the PC lap top and have a go.
Something strange did happen this weekend which got me to thinking about coding again. I took the car in for a dealer coolant flush and it seems that my simultaneous fogs and high beams is not working now. I'll check the double blink hazards if it ever stops raining this morning to see if they reset the FRM for some reason. Anyone have that happen? The only other thing I had them do is reset the service countdowns.
It's been way too long since I've done programing. I must have messed up some things getting DIS running awhile back. I took me awhile to get everything talking again for programing. At the end when I thought I had everything correct, strange things started showing up in the Tach display..Air Bag, Steering Wheel, etc. and the car was beeping at me. I thought I fried something. I unhooked everything and then the car wouldn't start. After freaking out a few minutes I finally realized the lights were on this whole time. DOH! Waited and few minutes and I just had enough juice to turn it over. WHEW!
After the battery was charged and everything back to normal I tried to program in one touch up windows in FRM since I don't have those in the 2007, but no luck. I've sent out some questions to those who have done it successfully. I still don't understand why my fogs + brights suddenly are not working. It's still coded correctly. Strange.
Anyway, I'm glad this forum was here to refresh my memory on how to get things working. Thanks!
TiggerGTO,
I'm not sure what is going on with the lights. It worked great when I programmed it awhile back and I'm almost positive it was working on the way to the dealership as I ran through some crappy weather on the way there and I had them on. I have four rally lights as well with two of them wired to turn on with fogs and two to turn on with brights. With that setting active and brights engaged I have fogs, brights, and all four rally lights burning so I know when its working.
I'm just not sure what would cause it to stop working out of the blue but I'm still tracing it back to the dealership doing something during the coolant flush and service countdown reset as they didn't work after that. I went on a rally the next day and was showing them off when I noticed they revered back to default behavior. I doubled checked the trace file and it is still set correctly there. FRM also has double blink hazards which I had set and it still works so it is a mystery at this point. I'm still digging.
PS: My auto up windows work great. Stupid me did not have the car "ON" when testing. It seems auto down works with just the key in, but auto Up needs the car on.
This isn't the setting for rolling them up with the FOB (I have that turned on too), this is "one touch" up with the toggle in the car. This feature seems to be default in 2008+ but my 2007 didn't have it.
As for the lights...more pilot error. I didn't realize there was a separate setting for Flash Brights w/ Fog. I was flashing them to test and the fogs were shutting off. When I actually turned the brights on the fogs stayed on just like they should. I'll add the setting for Flash Brights + Fog on the spreadsheet shortly. I turned it on too.
Hey guys,
I'm new mini owner 2012 Clubman S. Looking to see if anyone in my area (orange county, California) might have the means to do changes I want and make a little money doing so! If your interested PM me and we can talk. Otherwise I'll just have to do it myself haha.
Thanks Guys!
Thanks Guys!
INPA that gets installed alongside of NCS can read the codes and reset the airbag light (as well as most other modules).
Hi everyone,
I lack any technological knowledge of any kind. So, please forgive me if this is a ridiculous question.
I'm really interested in adding the option that allows me to roll my windows up with my fob. I would also like to get rid of the seatbelt chimes. However, as previously mentioned, I lack the ability to do this myself. Would it be possible to take my car into the dealership and have this done? Or would they have no idea what I'm talking about?
