Electrical Rear fog lites as brake lites?
Old May 26, 2010 | 07:57 AM
Dwight Walhood's Avatar
Dwight Walhood
Is there a way to wire the rear fog lites so they work in tandem with the brake lites, but can still be used as fog lites? Is it an "either-or" thing? Just want everyone to know I'm on the brakes, LoL. Thanks.
Old May 26, 2010 | 08:07 AM
schatzy62's Avatar
schatzy62
You would have to add some wiring and diodes to make this work. But I believe it is possible.
The only thing I would worry about is when you are using the rear fogs then only the brake lights would work, and that is when you really want the extra light from what yo are trying to accomplish, or at least that is how I see it.
With the normal brake lights and the third brake light IMHO there should be enough light to make the person behind you notice you are "on the brakes".
it the do not see that then they probably are not looking and would not see the extra light from the fogs as brake lights either. But of course that is just my opinion.
Old May 26, 2010 | 08:54 AM
rkw's Avatar
rkw
The GoMiniGo kit does the either/or function: http://gominigo.com/BLK-MINI.html
Electrically it only requires adding a couple of diodes.
Old May 26, 2010 | 09:22 AM
Dwight Walhood
Thanks a bunch RKW! Will get on the horn to them today. I'm the cautious type, would turn the whole rear end into a particle laser if I could, LoL.
Old May 26, 2010 | 10:06 AM
Speedee's Avatar
Speedee
That kit will not work on your car... it is for an '02 through '04. After 04 the rear brake lights and fogs were a totally different set up.
Old May 26, 2010 | 11:09 AM
schatzy62's Avatar
schatzy62
Not true they make a kit for the R56
Old May 26, 2010 | 11:22 AM
rkw's Avatar
rkw
You need to scroll further down the GoMiniGo webpage.
Old May 26, 2010 | 02:01 PM
Dwight Walhood
Read their whole add. The kit I ordered is specifically for the '07+ MCS.
Old May 26, 2010 | 04:17 PM
MINI33342's Avatar
MINI33342
Or just get the 3rd brake light pulsar. Very eye-catching!
Old May 26, 2010 | 04:28 PM
mickeyR57sparkling's Avatar
mickeyR57sparkling
Not sure why you need to have the fogs switched, because 99% of the time your Headlights are on with fogs anyway
I did this using LED Foglights, and it worked perfectly...the LEDs can handle the Parking as well as Brake Light brightness
I didnt use the the wiring kits, i just wired them directly. I used the below PDF file for direct wiring. The only thing you have to make sure that the polarity for the LED fogs are correct, however its easy to tell. If the polarity is wrong, hey wont work and just reverse the 2 wires.
http://www.images.gominigo.com/INSTR...7-conv_BLK.pdf
https://www.northamericanmotoring.co...foglights.html
Dec 23, 2015 10:36 AM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
