Electrical Info on A/f ratio gauge installation?
Old Aug 27, 2008 | 02:39 PM
jollyroger927's Avatar
jollyroger927
I searched and couldnt find anything so deicded to post. I am interested in getting a prosport A/f ratio and voltage gauge but was wondering how would i install the A/f ratio. I know where the guage is going but not much about how to install the reader.
Any help about a/f ratio gauges would be awesome, even if it doesnt involve the prosport one.
Old Oct 27, 2008 | 08:34 PM
Malcon's Avatar
Malcon
bump
Old Oct 27, 2008 | 08:47 PM
jollyroger927
Yea i still need help with this.
Old Oct 28, 2008 | 12:51 AM
MINIdriver85's Avatar
MINIdriver85
The A/F ratio reads from the O2 ports on the exhaust header, there are two stock O2 sensors, now I don't know if a normal A/F ratio gauge needs to take the place of one of those or not, because I've always looked for wideband A/F gauges which need another bung welded into the header for their sender, sorry but this is the best I can tell you.
Old Nov 29, 2008 | 01:35 PM
MaxMini81's Avatar
MaxMini81
Wanderer
On my Honda it was a simple tap into a sensor wiring harness... I doubt its much more complicated than that, but I also need to know as I just picked up an AutoMeter A/F gauge today. Help!
BUMP
Old Nov 29, 2008 | 02:44 PM
not-so-rednwhitecooper
If it taps into a stock O2 sensor, its a useless narrow band gauge. It reads in such a small range, its just another flashy thing to put on your dash.
A wide band O2 sensor needs either a hole drilled in the exhaust or a bung welded on before the cat. It will have a wiring harness that runs to the gauge. These gauges generally read from 8:1-18:1 a/f.
Old Nov 29, 2008 | 02:47 PM
http://www.aempower.com/ViewCategory.aspx?CategoryID=70
The gauge you want ^^^
The gauge you DONT want vvv
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 29, 2008 | 04:07 PM
Professor's Avatar
Professor
Originally Posted by not-so-rednwhitecooper
This man speaks the truth. If you want pretty flashy lights that tell you nothing the a narrow band will work just fine. But for real time A/F info and the ability to data log that info get something like the AEM. Autometer also makes a new wideband but get ready to pay almost 400 bucks.
Old Nov 29, 2008 | 04:40 PM
JustAnotherWideband (JAW) is hands down the best deal, but if you dont want to make a case for it, the AEM is the best alternative.
They can be had new for about $220, or used on eBay for less than $150
Old Nov 30, 2008 | 11:31 AM
MaxMini81's Avatar
MaxMini81
Wanderer
K so I got the worthless one alright I admit it I didnt do my research. that said, HOW DO I CONNECT IT? there has to be a signal wire somewhere. There must be an O2 sensor somewhere. ANYONE point my in the right direction. Thank you
Old Nov 30, 2008 | 11:34 AM
Just put 12V power to it, why bother hooking it up? Its just gonna dance around and cause you to take your eyes of the road!
Old Nov 30, 2008 | 12:44 PM
MaxMini81's Avatar
MaxMini81
Wanderer
Very Helpful... Thanks, @$$...
Old Nov 30, 2008 | 12:53 PM
MaxMini81's Avatar
MaxMini81
Wanderer
If anyone is having problems installing an AutoMeter Air Fuel Ratio Gauge, and is sick of being run around the forums and taking ***** from people about the gauge itself, I found this it also includes Boost Gauge Instructions.
http://www.mossmotors.com/graphics/p...ns/100-921.pdf
Old Nov 30, 2008 | 01:35 PM
I'm an *** to stop people from wasting money.
You obviously don't give a crap what an air/fuel gauge does, so why bother putting it in?
If your putting in a narrow band a/f gauge, you don't need an a/f gauge to begin with, its mind boggling.
I read the Moss guide, and they are telling you to tap it right off the ECU which is a stupid idea. Tap the white signal wire coming off the O2 sensor on the sensor side of the plug, so if you screw it up, your not replacing the engine harness or doing a lot or unnecessary wiring repairs.
Old Nov 30, 2008 | 03:07 PM
MaxMini81's Avatar
MaxMini81
Wanderer
Fine, I was just asking for help having already bought one... where is the O2 sensor located. Sorry for the *** comment. I really just wanna get it in, I guess for the light show.
Old Nov 30, 2008 | 03:22 PM
Exhaust system. The plug is on the left side of the head between the airbox and the valve cover.
It is 4 wires, sensor side is gray, gray, white and black. Tap that white wire and run that to the (purple I think) on your gauge.
Old Nov 30, 2008 | 03:59 PM
big howe's Avatar
big howe
Narrow band A/F gauge? I didn't know there was such a thing. It will read like a saw tooth. High/low/high/low, unless on the gas then it's overloaded rich. Won't really tell you much, performance-wise that is.
I don't think anyone is trying to be an ***, but a narrow band A/F gauge is like a two position gas gauge, full/empty. Doesn't help you a whole lot.
Old Nov 30, 2008 | 07:53 PM
MaxMini81's Avatar
MaxMini81
Wanderer
Its actually gray, white, white, black... so idk. maybe I'm just gonna give up on this tedious, pointless venture
Old Nov 30, 2008 | 07:57 PM
Then the gray wire is signal.
Whites are heater and black is ground.
Its been a while since i've needed to go down there.
Old Dec 1, 2008 | 04:48 PM
MaxMini81's Avatar
MaxMini81
Wanderer
That ended up not working, but whatever thanks for trying I give up.
Old Dec 1, 2008 | 09:51 PM
jollyroger927
Thanks for all the info guys. Hopefully i can try to get mine connected even tho i now know it is a stupid gauge.
Old Dec 2, 2008 | 09:03 AM
MaxMini81's Avatar
MaxMini81
Wanderer
Let me know how it goes cuz I couldn't get mine up and running. Theres a way of tapping into the ECU harness, but I've been advised against it and frankly i agree.
Old Dec 2, 2008 | 03:26 PM
Bahamabart's Avatar
Bahamabart
i added a wideband by simply adding another bung to my header
Old Dec 23, 2008 | 10:14 PM
mini_racer's Avatar
mini_racer
For those of you with a wide band, like the AEM or other. Have you utilized it for a custom tune? Like an RMW custom tuning session?
My recent Jan/RMW tune was performed with just ECU readings, so I guess that would be narrow band only. Would you expect a tune to be more accurate , and therefore better using a wide band for AFR??
Old Dec 23, 2008 | 10:29 PM
big howe's Avatar
big howe
My guess is there was a tailpipe unit for the dyno tune, so while it was an after cat measurement, there were still wideband readings for your tune. Having a wideband installed just for the tune probably wouldn't have changed the tune at all.
As for running the gauge as a tool, it never hurts to keep an eye on things, especially the harder you flog your car.
