Electrical Gauges installed!
Old Mar 2, 2008 | 09:24 AM
  #126
masterd78's Avatar
masterd78
MANIAC
That sucks, sorry to hear it. Tell us what the problem was when you find out.
Old Mar 2, 2008 | 02:53 PM
  #127
sailorliz23's Avatar
sailorliz23
Originally Posted by spfdhed
I have an automatic, so I (don't) think the shifter comes off (easily), so I just lossened the console and held it up ~3-4 inches and did the wiring that way. A little tight, but I got to the wires for tapping ok. BTW, I am still having trouble with my boost gauge. It worked for 2 days, then quite registering boost, vacuuum, after the start up sweep. The guys at Alta sent me another transducer which worked for 10 minutes! I am in contact with Alta and the Prosport guys to figure out the cause
hey pm me or my husband (lxjose9xl) and we can try to help you with anything you need. my mini is auto too so yes it was very hard to get the shift **** off and its even harder to put it back on. he also created his own connection from the sensor to the tube connected to the gauge that measures boost.
Old Mar 2, 2008 | 06:27 PM
  #128
poolemac's Avatar
poolemac
hey guys,
Stupid question: how do you program the guages to be red or white? does it get connected to the headlights switch? what if you wanted it to be red all the time?
TIA..
Old Mar 2, 2008 | 07:29 PM
  #129
chili_red07's Avatar
chili_red07
It depends on how you wire it, but there are instructions for when the gauge is red/ white (and no, it is not wired to the headlight control.)
Old Mar 3, 2008 | 09:56 AM
  #130
masterd78's Avatar
masterd78
MANIAC
Changing the color setup is as simple as switching the wires around from Illumination and 12volt switched. It's a simple change that can be done when installed in 2 seconds.
Old Mar 3, 2008 | 05:49 PM
  #131
chili_red07
^what he said
Old Mar 4, 2008 | 08:59 AM
  #132
joshK's Avatar
joshK
I installed my gauges last night. They work great and look fantastic BUT:
Did anyone else have a problem with the gauges rattling and if so, how did you remedy this?
Old Mar 4, 2008 | 09:00 AM
  #133
chili_red07
I noticed it too, and believe its the little silver button. I haven't figured out how to shut it up yet.
and am I the only one who is annoyed by the start-up beep?
Old Mar 4, 2008 | 12:54 PM
  #134
spfdhed's Avatar
spfdhed
#1. To shut off the initial alarm, hold down on the button while starting and that should silence it (check the instructions that came with the gauge).
#2. The rattling is from the buttons as they pass thru the lexan/plexiglass or whatever the face is made of. I called Prosport (Alta didn't have a fix) and they told me to ever so slightly turn the gauge bezel to "firm up the lens on the shaft of the button". I have not done this yet and I am waiting for a new transducer and I am going to redo the install (using the felt rather than the 3m tape to "lock" the gauges in the cups.
Old Mar 4, 2008 | 04:30 PM
  #135
chili_red07
thanks for the info spfdhed!
Old Mar 5, 2008 | 01:29 AM
  #136
danielo's Avatar
danielo
Guys,
I checked today.
My R56 doesn't have a MAP sensor. I guess it's a different spec that the US spec cars.
How else can i tap the boost sensor to the car? I was hoping there would be a clean and nice way to do it just like how Alta has that stand-off plate.
Old Mar 5, 2008 | 04:51 AM
  #137
chili_red07
Well, I silenced the start-up alarm no problem, but I can't for the life of me get the face of the gauge to turn for the damn rattling. Any thoughts?
Old Mar 5, 2008 | 06:42 AM
  #138
spfdhed's Avatar
spfdhed
You might give Prosports a call. They are very nice to talk to. Google for the contact info. (I haven't tried to turn mine yet. I will try tomorrow).
Old Mar 5, 2008 | 10:02 AM
  #139
johne123's Avatar
johne123
oil temp update
I don't really have much of an update. I received my oil temp gauge from ProSport but it was too deep to use next to the tach. It was also missing the sensor, so I was able to send that back and I placed an order for the correct shallow gauge yesterday. The premium peak/warn 52mm and premium peak/warn 60mm are the only shallow gauges from them that will work.
For those looking at going oil temp and pressure, the sensors that ProSport supplies are actually quite small. As soon as I get mine I can start looking at what it will take to make an adapter.
Old Mar 5, 2008 | 10:08 AM
  #140
masterd78's Avatar
masterd78
MANIAC
I too have the rattle from the button. I am working on a fix right now, I will let you all know how it goes.
Old Mar 5, 2008 | 07:41 PM
  #141
chili_red07
any luck
Old Mar 5, 2008 | 07:49 PM
  #142
masterd78's Avatar
masterd78
MANIAC
Give me til morning I think I've got something.
Old Mar 5, 2008 | 08:09 PM
  #143
masterd78's Avatar
masterd78
MANIAC
Here are some pics and I do have them installed. You are still able to push the buttons, but no rattle. Pics tomorrow. I think it looks good, not perfect but better than it rattling.
Supplies. Paper punch, Outlet Sealer (or similar foam), and razor blade.
Old Mar 5, 2008 | 08:10 PM
  #144
masterd78's Avatar
masterd78
MANIAC
Punch some holes in the outlet sealer like this.
Old Mar 5, 2008 | 08:12 PM
  #145
masterd78's Avatar
masterd78
MANIAC
Then I cut a slit in the small punch out piece so it looks like PacMan. Hard to tell from the pic. Then take it out, pull the button out a tad, open up Pac Man and have him munch the button. It works well, and looks decent.
Old Mar 6, 2008 | 05:18 AM
  #146
spfdhed's Avatar
spfdhed
Good move. You can probably also "punch out" a couple of pac-men from the felt (one side sticky) that came with the gauges.
(I like your purple hole punch...it matches the packaging on your plug insulation...)
Old Mar 6, 2008 | 08:05 AM
  #147
chili_red07
^DING DING DING!!! That sounds like a perfect solution!
Old Mar 6, 2008 | 08:38 AM
  #148
masterd78's Avatar
masterd78
MANIAC
My initial feeling is that it works well. I drove it to work today with them on, and it is way better. As for the purple punch, I had to force myself into Roberts Craft Store to buy it.
Old Mar 6, 2008 | 09:22 AM
  #149
chili_red07
I went out and used the foam tape and it works like a charm. I think I'll redo it, because it ain't pretty! (I couldn't find the hole punch, so I used an x-acto knife.)
Also, I just cut a slit in the middle of the circle (not to the edge) for aesthetic reasons.
Old Mar 6, 2008 | 09:51 AM
  #150
masterd78's Avatar
masterd78
MANIAC
I just did the full slit, and I think it looks good. I really doubt anyone will ever even notice. And I don't think it looks bad at all. Glad it worked for ya!
