Drivetrain JCW Air Filter help needed.
Old Mar 26, 2007 | 02:20 PM
goaljnky's Avatar
goaljnky
I am trying to change out the filter, but I am having a problem removing the top of the airbox. Does anyone have a how-to, or a helpful suggestion?
Thanks.
Old Mar 26, 2007 | 03:09 PM
buzzsaw's Avatar
buzzsaw
Go to www.jwardell.com/mini. It really helped me.
Old Mar 26, 2007 | 03:13 PM
BFG9000's Avatar
BFG9000
After undoing the screws, you have to slide the boxtop toward the firewall hard enough to deform the plastic there in order to release the rear hooks.
Mini Works's Avatar
Mini Works
Hello Goaljnky,
Thanks again for the warm welcome, you and your MININUTS friends rule, we had a great time with you guys at dinner.
Give us a call at the shop, if you still have problems with that JCW filter.
Good luck
Victor
Old Mar 26, 2007 | 04:14 PM
goaljnky's Avatar
goaljnky
It was a pleasure meeting you Victor. Now I have the next question. Is the hose clamp from the hose on the air box supposed to be reusable, does it need a special tool, or do I need a new clamp? I can't seem to get it to latch.
Old Mar 26, 2007 | 05:57 PM
buzzsaw's Avatar
buzzsaw
The clamp is reuseable. Take a pair of pliers in the extended notch position and grasp the left side and the right side of the open clamp and squeeze it together slowly and voila it snaps together.
Old Mar 26, 2007 | 05:59 PM
goaljnky's Avatar
goaljnky
Yes it does. Thank you. Can't believe there isn't a how-to out there, even if it is a 10 minute job. I guess the biggest mystery were the two clamps in the back. Go figure.
Old Mar 26, 2007 | 07:38 PM
mbcoops's Avatar
mbcoops
I found a how-to on here somewhere a while back, or at least a link to one. Getting that metal clamp back on took the longest out of everything. I hate to think about it.
mb
Old Mar 26, 2007 | 08:03 PM
kapps's Avatar
kapps
If it's the same metal clamps that are on the regular stock intake, they can be fun. I found the best way to get them back on was to use some pliers and a small flathead screwdriver. Use the screwdriver to hold the clip up so it doesn't get snagged when clamping with the pliers.
silence2-38554
98
Sep 21, 2016 02:52 PM
The_Kid
Aug 28, 2015 04:50 AM
polotska
Aug 23, 2015 09:10 AM
minipopkart
Aug 13, 2015 05:22 AM
