Drivetrain Help! Removing M716% for Alta V2
Old Mar 10, 2007 | 08:59 PM
daemon2's Avatar
daemon2
Has anyone removed an M7 or other pulley to replace with another? I am having a hard time getting the M7 off.
Any ideas or suggestions appreciated
Old Mar 10, 2007 | 09:14 PM
cooldaddy's Avatar
cooldaddy
besides the 4 holes for the normal bolts there are 2 extra holes that are threaded. Get some longer bolts that have the right thread and use these to pull the pulley of the shaft. The pulley can get stuck on, mine was and the use of the 2 extra holes worked great
Old Mar 10, 2007 | 09:18 PM
daemon2's Avatar
daemon2
Thanks!
I will give this a try, do you know if they are the same threads as the 4 bolts removed from the pulley?
Old Mar 10, 2007 | 09:22 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
I would guess so...
Why are you changing the M7 pulley for the Alta V.2? Going from 16% to 19%?
Old Mar 10, 2007 | 09:23 PM
cooldaddy's Avatar
cooldaddy
I think they are, but if I remember correctly the thread on the bolts that come with the pulley is not long enough for this operation (the threads don't run all the way to the head of the bolt)...
Old Mar 10, 2007 | 09:25 PM
daemon2's Avatar
daemon2
I just checked and the supplied bolts are too short. I will pick some up at the hardware store tomorrow.
I do not require a puller right, just thread in the new longer bolts into the 2 holes until the 2 halves separate?
Old Mar 10, 2007 | 09:27 PM
daemon2's Avatar
daemon2
I am going from the 16 to 17%. I had some issues with pulley alignment with the M7, it was eating belts and causing the belt tensioner to rattle.
Originally Posted by DarkMiniCooperS
I would guess so...
Old Mar 10, 2007 | 09:34 PM
cooldaddy's Avatar
cooldaddy
correct, tighten the 2 bolts in small amounts until the pulley pops off...
Old Mar 10, 2007 | 09:35 PM
daemon2's Avatar
daemon2
I owe you one.
Old Mar 11, 2007 | 11:33 AM
jibeho's Avatar
jibeho
5400 miles on my Alta V2 17%, aligned right up and the gatorback belt still looks nice and fresh
cawwwtun
May 3, 2016 08:03 AM
melscoop
Mar 30, 2016 06:56 PM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
greekzilla
Aug 23, 2015 03:44 PM
