Drivetrain idle problem
Old Feb 27, 2007 | 10:07 PM
DjR53's Avatar
DjR53
idle problem
Just installed an alta intake about last wednesday, drove it pretty good to get the ecu adapted to its new flow, but i have noticed over the passed few days that when im at idle it goes from 900 to 800 and when it dips i get a vibration in the car anyone knows whats going on? thanx
Old Feb 27, 2007 | 10:13 PM
COR BLMY's Avatar
COR BLMY
Your "drive it pretty good" is on the right track.
Do a real ECU reset (battery disconnect or computer code reset) and see what happens).
Wasn't it REALLY cold down you way today ???
Old Feb 27, 2007 | 10:22 PM
DjR53's Avatar
DjR53
ya it was freaking freezing lol and its only 55 i know some east coasters are jealous even at that temp
Old Feb 28, 2007 | 12:02 AM
Bster's Avatar
Bster
To disconnect the batt... do you remove the red wire first, or black wire first? Positive or negative?
Old Feb 28, 2007 | 12:16 AM
COR BLMY's Avatar
COR BLMY
SOME even do this at the start of a track day not only to force the system to learn new parameters...
disconnect the NEG and wait a bit (2 / 3 min)
or
this is really easier
This will reset the adaptive learning / "cluster" reset
Hold in your odometer reset button and at the same time turn your key so that the radio comes on
Release the odometer button and then press it repeatedly until it shows the #19
Stop at 19 and the display will go back and forth between "test" and "off"
Push the button when it is on off and the press it repeatedly until you get to #21
It will display an option to reset. Press the button and your displays will go blank and your guages will flutter and then the displays will come back on
Turn off the key and then your done.
Takes less than 60 seconds and you don't need to to unhook the battery or reset your clock
Old Feb 28, 2007 | 04:54 PM
DjR53's Avatar
DjR53
is this problem just all in my head??? is this perfectly normal?
Old Feb 28, 2007 | 05:35 PM
jhiggs26's Avatar
jhiggs26
You could also try checking your spark plugs/lead connections and run a bottle of fuel injector cleaner too!
iggi
18
Feb 9, 2026 01:00 AM
Marco Guardado
Sep 15, 2015 01:22 AM
Sep 1, 2015 03:36 PM
robbiedowns22
Aug 25, 2015 12:20 PM
Lt. Dan
Aug 10, 2015 08:23 AM
