Drivetrain more boost???
Old Feb 27, 2007 | 07:33 PM
catchMCS's Avatar
catchMCS
more boost???
so i plan on buying a new pulley tom.. i am sticking with all Alta parts so im not sure if i should get the Alta Classic or the Version 2.0... what do you guys think??? please let me know im still pretty new at this Thanks
Old Feb 27, 2007 | 07:39 PM
inimmini's Avatar
inimmini
I'd say you should go with the Helix pulley -- 6 bolts instead of 4 like the Alta.
Old Feb 27, 2007 | 07:45 PM
norm03s's Avatar
norm03s
2nd that
Old Feb 27, 2007 | 07:58 PM
soilsample's Avatar
soilsample
I strongly suggest the updated 2nd version.
Old Feb 27, 2007 | 08:21 PM
jhiggs26's Avatar
jhiggs26
The Version 2.0 looks good........lighter too as the body of the pulley is "ultra light aluminum". (From Alta's website.) I've had the original Alta 15% reduction pulley for 25000 miles or so and it's just fine with the 4 bolts. Just use blue loctite when fastening!
Old Feb 28, 2007 | 09:56 AM
MINIotaple's Avatar
MINIotaple
That's not the reason I would get the helix. Interchangability is the best part. Paying $50 to move to a 19% is much better than buying a whole new pulley for $100+. You pay similar prices for either the Alta or the Helix, but you get interchangability with the Helix. You may think you'll be fine with a 15%, but then again, maybe you won't. I ended up going from a 15% to a 19% in less than 5000 miles.
Old Feb 28, 2007 | 05:21 PM
jhiggs26's Avatar
jhiggs26
Yes the interchangability of the Helix pulleys is a benefit! MINIotaple how do you like the 19% compared to the 15%? Is the extra boost FUN low down in the revs compared to the 15%? Have you tracked your car-logged lots of continuous 4500 plus rpm-and had no drive belt issues? Thanks!
Old Feb 28, 2007 | 06:57 PM
catchMCS's Avatar
catchMCS
ok so i just bought the helix 17% pulley clamp on-style ($120) but can I use any mini pulley puller and belt tensioner tool... to change my pulley?? thanks
Old Feb 28, 2007 | 06:59 PM
jhiggs26's Avatar
jhiggs26
YES
Oct 1, 2015 12:13 PM
patsum
Sep 30, 2015 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
mbatech
Sep 10, 2015 03:40 PM
