Drivetrain Quick seafoam question
Old Feb 17, 2007 | 03:54 PM
Longboard110's Avatar
Longboard110
Due to my annoying pinging problem that will not go away im going to try seafoam. Since i have an oil catch can the gray line that goes to the supercharger is easily accessible for my place to add seafoam. I just wanted to make sure this was a kosher spot before i did it. Thanks
Old Feb 17, 2007 | 04:26 PM
Longboard110
also do i have to change the oil if i only add it to the intake path?
Old Feb 17, 2007 | 05:54 PM
Longboard110
nevermind, figured it out
Old Feb 17, 2007 | 06:10 PM
thulchatt's Avatar
thulchatt
enlighten me, did you use that line?
Old Feb 17, 2007 | 07:19 PM
Longboard110
i actually used a different product, but yes i found you can use that line
Old Feb 17, 2007 | 08:39 PM
Kellzir's Avatar
Kellzir
What product did you end up using? and did it get rid of the pinging?
Old Feb 17, 2007 | 08:42 PM
Longboard110
i used Amsoil power foam engine cleaner, ill give results tomorrow
Old Feb 18, 2007 | 11:19 AM
Longboard110
well finally got a chance to take it out for a good spin, and the amsoil seemed to help. The pinging is still there but not nearly as audible as before. I did not use the entire can so i may give it a second blast tomorrow to see if i can clear it up completely
Old Feb 18, 2007 | 12:36 PM
Wake|MCS's Avatar
Wake|MCS
excuse my ignorance in the subject.. but what exactly does the foam do?
Old Feb 18, 2007 | 01:01 PM
Longboard110
it cleans up the intake path of the engine from carbon and other gunk
Old Feb 18, 2007 | 01:40 PM
thulchatt's Avatar
thulchatt
It is not foam, just the name. Fuel additive or through the intake.
I have also read of using water the same way. I won't be going there but Sea Foam is combustable so safer.
Old Feb 18, 2007 | 02:07 PM
Longboard110
the amsoil power foam is actually a foam from an aerosol can you spray directly into the intake
iggi
18
Feb 9, 2026 01:00 AM
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
PhoenixR61
Aug 21, 2015 07:40 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
