Drivetrain Blue exhaust ( smoke )
Old Jan 30, 2007 | 09:59 AM
piston's Avatar
piston
It seems one of my roomates informed me that when I am WOT and nearing the upper 5k RPM marks my car emmits blue exhaust. I am hoping that it isnt the rings ( or that the rings havent set properly) I only use Mobil 1 full synthetic oil..
Old Jan 30, 2007 | 10:57 AM
camelpilot's Avatar
camelpilot
you sure its blue and not black?
Old Jan 30, 2007 | 10:59 AM
BE4TNUT's Avatar
BE4TNUT
How many miles on the car and what year is it?
Old Jan 30, 2007 | 11:05 AM
camelpilot's Avatar
camelpilot
fwiw I have seen a few JCW cars smoke on acceleration. They smell rich too when u follow them. Has your car got bigger injectors than stock?...
Old Jan 30, 2007 | 11:14 AM
cooper99's Avatar
cooper99
I'm no mechanic, but I know blue smoke out the exhaust means you are burning oil.
I know in older cars this usually happens from worn gaskets or o-rings and oil begins to leak into a cylinder, which causes misfires and fouls the spark plug.
Do you have any mods on your MCS?
Old Jan 30, 2007 | 11:16 AM
piston's Avatar
piston
05' Cooper S
Nearing the 56k mark
Old Jan 30, 2007 | 11:17 AM
piston's Avatar
piston
He said that it STARTED black ( which i know is normal for a car with boost ) and then near the upper RPMs puffed blue.
justintime's Avatar
justintime
I noticed that too
Old Jan 30, 2007 | 11:18 AM
piston's Avatar
piston
Yes My MCS is modded, but only with the basics. CAI/Pulley/ etc. (Nothing major.)
Old Jan 30, 2007 | 11:19 AM
piston's Avatar
piston
"Has your car got bigger injectors than stock?"
Negative.
Old Jan 30, 2007 | 11:20 AM
cooper99's Avatar
cooper99
Originally Posted by piston
05' Cooper S
WOW almost 30k miles a year!?
Old Jan 30, 2007 | 11:21 AM
SharoSC02's Avatar
SharoSC02
Have you done any head work and or an upgraded head?
Old Jan 30, 2007 | 11:23 AM
piston's Avatar
piston
hehe, I like to drive
SharoSC02's Avatar
SharoSC02
It could be the fact of the way you have driven the car and the maintenance of it or lack thereof, just assuming of course. Doing the process of elimination.
piston's Avatar
piston
Refer to an above post. ( only basic mods )
Old Jan 30, 2007 | 11:26 AM
SharoSC02's Avatar
SharoSC02
yeah got that, I was posting the question while you had yours on.
Old Jan 30, 2007 | 11:29 AM
piston's Avatar
piston
No problem
Id say that I broke it in almost to spec. And the oil changes were done by my local Mini dealership until a few months back.
Old Jan 30, 2007 | 11:30 AM
piston's Avatar
piston
As for driving it hard; I am a member at the local race club ( Chin Motorsports) and have ran tracks such as Homestead.
Old Jan 30, 2007 | 01:37 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
I think that most of the blue smoke problems are caused mostly by oil buildup in the intercooler. I had this minor issue which went away upon adding an oil catch can. Since the oil tends to accumulate via partial throttle applications when the PCV valve is working (some manifold vacuum), oil will mist and condense in the intercooler. If it has a chance to accumulate in large amounts, a WOT blast will 'sweep' some oil from the nooks in the intercooler and boots into the engine and burn it off. It's not a big issue, but can foul plugs if it's happening a lot.
Clean out the IC before making some full throttle runs and see if the smoke recurs. I bet it doesnt.
Old Jan 30, 2007 | 01:53 PM
herbie hind's Avatar
herbie hind
then if it does recurr ... do a compression test .
Old Jan 31, 2007 | 04:03 AM
MCSJCW's Avatar
MCSJCW
Hello
Blue smoke it is because your car is burning Oil... is not a good thing...
A question, when i start my JCW he makes black smoke... it is normal?
Best Regards
Old Feb 1, 2007 | 06:54 AM
Wesport's Avatar
Wesport
I run big injectors and cold t-stat. This combo makes the car to rich on cold days - even with correct GIAC flash. I load up carbon in the cat and exaust and a hard burst will give black smoke for a few seconds while it clears out. I may change back to a stock t-stat for winter and see if that fixes it.
Wesport
minicoclub
Nov 11, 2015 07:25 AM
tr3y003
Oct 22, 2015 10:48 AM
Gil-galad
Eastern Iowa MINIs
17
Sep 12, 2015 07:13 AM
Lt. Dan
Aug 10, 2015 08:23 AM
