Drivetrain installed supersprint 4-2-1 header + race pipe
Old Apr 30, 2003 | 07:07 AM
SMG's Avatar
SMG
here are some pics
center pipe
_________________
Old May 1, 2003 | 10:46 AM
SMG's Avatar
SMG
if i have to rank all my mods so far, pls. see below. (1-10)
intake - 6
header -9
exhaust - 6
pulley & ecu - 10
coilovers (not just springs) - 9
light weight wheels & good tires - 10
hope it helps.
header is almost just as good as the pulley & ecu mod imo.
Old May 3, 2003 | 04:38 PM
TwOMINIs's Avatar
TwOMINIs
How 'bout a sound bite of that exhaust?
His, Chile Red all over/ Hers, EB, UJ on top
Old May 4, 2003 | 06:50 PM
Ravenwhyte's Avatar
Ravenwhyte
Hi SMG,
Nice post - helpful, there a lot coming out for mods and sometimes it's tough to know where to begin. I wonder if you could explain the "kicking in' sensation at 3500. I am not sure I understand the physics of what a performance header does, except perhaps reduce exhaust pressure?
Thanks,
Raven
Old May 4, 2003 | 08:57 PM
SMG's Avatar
SMG
the ecu & pulley didn't help the rpm needle fly up any faster but it makes more boost.... but the header & center pipe mod. makes the rpm needle flyup much faster than stock header....and it truely works well with the ecu & pulley mod....so now the rpm needle flyup faster and the extra boost increase make the car alot faster than stock from 3500rpm up.....
before i had the header & center pipe mod, i can feel the extra boost but i can also feel that the flow isn't great.....but this feeling disappeared
if i am to mod. my car all over again, this will be the sequence of mods.
engine performance.
1. airbox
2. header with race cat + cat back
3. pulley & ecu
4. lightweight flywheel & street racing clutch
handling.
1. light weight wheels & grippier tires
2. coilovers (not just springs)
3. lsd
4. big brake kit
my way of modifiying the S may not be the cheapest way to do it .. but i'm happy with what it is now....
_________________
Old May 5, 2003 | 07:24 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
SMC-
Thanks for the great post, pics and your impressions.
Let me try to understand your addition:
Supersprint exhaust header with no cat-you used the stock cat?
Race center pipe? Where did you get that? Custom made? Larger diameter 2.5" for better flow?
You mentioned in your list of priority mods for performance- adding a Header with race cat- you mean with a built in cat like London Stainless header/cat or Mini mania Header and cat. (What made you decide to get the supersprint over these- and I thought I saw the supersprint header with cat for $650).
I looking into adding an exhaust header to my MCS. I am adding the Quicksilver exhaust. I don't have the pulley or ECU yet. Might not get it and just stick to suspension upgrades, madness intake, and throttle body upgrade when it comes out. Considering the header with Cat or not. Seems that the cat that comes with London Stainless or Mini madness is firmly sealed to the header- that is less joints=less chance for leaks=easier to install and less problems. Would you call the cat that comes with the header a racing cat-or is it the same quality as the stock cat?
What about weights- is this header upgrade the same less or more weight than the stock unit?
Thanks again for your excellent post- I really enjoyed seeing the pictures.
Old May 5, 2003 | 07:51 PM
SMG's Avatar
SMG
"Supersprint exhaust header with no cat-you used the stock cat? "
YES
"Race center pipe? Where did you get that? Custom made? Larger diameter 2.5" for better flow?"
WHEN YOU ORDER THE SUPERSPRINT EXHAUST, YOU CAN ORDER WITHOUT THE RACE PIPE AND USE THE STOCK ONE TO CONNECT TO THE SUPERSPRINT Y JOINT BUT I CHOOSE TO USE THE RACE PIPE COZ THE DIAMETER IS LARGER (CLOSE TO 2.5&quot AND IT'S LIGHTER THAN THE STOCK ONE, AND BETTER FLOW OF COZ.
"You mentioned in your list of priority mods for performance- adding a Header with race cat- you mean with a built in cat like London Stainless header/cat or Mini mania Header and cat. (What made you decide to get the supersprint over these- and I thought I saw the supersprint header with cat for $650). "
SUPERSPRINT MADE A RACE CAT THAT SOLD SEPARATELY AND YOU NEED TO WELD THAT TO THE HEADER (BUT NOT AVAIL. YET) THATS WHY I HV TO USE THE STOCK CAT. AND YES THE LONDON & MANIA SYSTEM IS EASIER TO INSTALL BECOZ THE CAT IS ATTACHED TO THE HEADER BUT I'M NOT SURE IF THE FLOW OF THOSE CAT ARE HIGH FLOW OR SAME FLOW AS STOCK. 650 IS JUST FOR THE HEADER WITHOUT THE RACE CAT.
SUPERSPRINT WEIGHT IS LIGHTER THAN STOCK 100% SURE.
THE SUPERSPRINT SYSTEM IS A BIT MORE EXPENSIVE THAN THE OTHERS BUT THE QUALITY IS FIRST CLASS.
I'LL POST SOME SOUND CLIPS NEXT WEEK.
Old May 5, 2003 | 08:11 PM
nfo's Avatar
nfo
SMG...
your car keeps getting better and better!
amazing!
what's next?
Old May 5, 2003 | 08:48 PM
SMG's Avatar
SMG
hi nfo, i think it'll be brakes but i'm still searching for some calipers that can fit under my wheels without spacers.
Old May 5, 2003 | 09:09 PM
Grinder's Avatar
Grinder
SMG, What do you do to make all this money?? Wanna send some my way? All I can do is drool over your car and dream that someday I'll have enough money to do even *some* of the mods you have...
Old May 5, 2003 | 09:21 PM
SMG's Avatar
SMG
Old May 5, 2003 | 09:24 PM
nfo's Avatar
nfo
hahhahahaa....
i was wondering the same thing grinder.
Old May 5, 2003 | 11:48 PM
minihune's Avatar
minihune
SMG-
Thanks very much for sharing your info and pics.
You and your mini mods inspire us
Keep safe- motor ON
Old May 5, 2003 | 11:50 PM
Azwed's Avatar
Azwed
Lots of money to be made in Hong Kong if you are in the right business and know the right people.
Old May 6, 2003 | 02:04 AM
SMG's Avatar
SMG
if i make lots of money, i'd have ordered a Work S ............ hahahah.......
JUST KIDDINGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG
_________________
www.imagestation.com/album/?id=4290882579
Old May 6, 2003 | 04:48 AM
gowest's Avatar
gowest
I'd like to see Randy get one of these for testing but it's my understanding they won't send him one because his numbers on the BMP intake were much lower than theirs.
Old May 6, 2003 | 12:41 PM
bbt4's Avatar
bbt4
SMG,
your exhaust system looks great! how was the fitment of the system?
but on a different note,
are those HID fog lights that you have?
i can't seem to find any H7 helogen bulbs greater that 4000K in the states.
i tried ebay and got ripped off.
i might install H7 HIDs.
what do you think?
bbt4
Old May 6, 2003 | 01:37 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Just to address this question, I haven't been able to get flow rates on the Mania cat, but the LS header is definitely a quality high flow cat at 200 dpi. This is a great flow rate but still does not trip the Service Engine Soon light. I believe the race cat BMP was using still had issues with this, so that may be the hold up. It was a higher flow though - I think 100 dpi, so there may be a new design that takes care of that.
Old May 6, 2003 | 03:50 PM
BlueThunder's Avatar
BlueThunder
That's not true!
In my 26 years of business i've never refused to sell anyone parts! Keep in mind this is my only job, if I don't sell parts I don't eat!
If your talking about a FREE system, We have that also, one of those will be going to Mark Ferguson for his race car. You may check with him after he gets it installed.
Old May 6, 2003 | 07:32 PM
SMG's Avatar
SMG
hey bluethunder, can i get a free cat for evaluation purposes?????? i've got eveything but the cat
the header makes the car's response so much better than before....
bbt4 - the fitment is perfect as you can see from the pics.....the only problem is you hv to find someone who knows what they're doing.....especially when you weld the stock cat to the header adapter....other than that, it's quite straight forward....
my fog lights are not HID......they're just some whiter bulbs which i got from my shop...i'll ck with them and let you know what they are.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
bleonard1401
Aug 11, 2015 02:53 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
