Drivetrain JCW+Schrick or 2% Crank pulley??? Anyone?
Old Dec 18, 2006 | 08:28 PM
davisflyer's Avatar
davisflyer
Just wondering if anyone has added a schrick cam or 2% larger crank pulley to an otherwise stock JCW MCS. If so, what were your results, seat of the pants or dyno. Thanks
Old Dec 18, 2006 | 08:40 PM
schooner2's Avatar
schooner2
I just did this to my JCW, I put the alta 2% oversized crank pulley and a ultrick cam that has the same spec as the shrick, the but dyno says its faster, I have 2 more pounds of boost. and i just pulls like Madd in all the RPM ranges. The motor rev's up faster. I dont notice any extra vibrations, and the motor sounds deeper with the cam.
Old Dec 18, 2006 | 08:48 PM
cooper99's Avatar
cooper99
If you already forked out 28k for a JCW, $400 for a cam and $150 for a crank pulley should feel like pocket change. Also those are probably the best bang for your buck power mods you can do.
Old Dec 18, 2006 | 09:15 PM
davisflyer's Avatar
davisflyer
Thanks. I read somewhere that a new cam is really needed to wake up a ported head.
Old Dec 18, 2006 | 09:17 PM
davisflyer's Avatar
davisflyer
Well, maybe not pocket change, but yeah....that's why I picked those two mods to ask about. Other than adding a header $$$, these are where the power potential seems to be on a JCW car.
Anyone else???
Old Dec 19, 2006 | 04:44 PM
chuckt's Avatar
chuckt
Why not go for the +4% crank pulley instead? That ratio will put you just off a 19% equivalent.
Old Dec 19, 2006 | 07:34 PM
davisflyer's Avatar
davisflyer
You know, I just saw today that Alta has a +4%. I wonder if having such an increase in boost would set off any codes?
Old Dec 20, 2006 | 05:13 AM
chuckt's Avatar
chuckt
It should give slightly less boost than a -19% SC pulley alone, virtually equivalent to the M7, -16/+2% combo.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
VanisleRyan
Sep 30, 2015 08:35 PM
daviday
Sep 25, 2015 01:31 AM
