Drivetrain Will this work?
Old Dec 10, 2006 | 07:19 PM
Maxicooper's Avatar
Maxicooper
Will this work?
My MCS already has JCW intake, JCW exhaust installed.
I'm just wondering if....we add 15% pulley, JCW Belt (for a peace of mind), JCW fuel injectors and spark plugs, would we be able to use the JCW ECU upgrade? since the only different is the ported and polished cylinder head that we don't have.
Need some input.
Thank you.
Old Dec 10, 2006 | 08:33 PM
Alex@Helix's Avatar
Alex@Helix
May I ask why you want to use all JCW items?
If you keep your current mods, you would see more power with a 19% pulley (with new belt), injectors, and a different ecu (i'm biased to GIAC, but there is also Unichip, MTH and Fireball). Are you trying to keep it as close to JCW as possible because of the warranty?
Old Dec 10, 2006 | 08:56 PM
Maxicooper's Avatar
Maxicooper
Yes, warranty is one of the reason.
My plan is to have the JCW kit install, but it will be sometimes later on next year due to I have already spent most of this year budget on suspension, exhaust, etc.
I found that if I would be able to just have dealer install aftermaket pulley and get other JCW hardware (spark plugs, belt, fuel injectors) plus their JCW software, that might be a good alternate route (cheaper, I think).
Also, JCW supercharger pulley is almost equal to 15%, then the only different from the JCW will be only the ported and polished cylinder head.
And then when ever I'm ready, I can add the JCW supercharger and the cylinder head.
My goal is to have ~25hp over stock.
Old Dec 10, 2006 | 08:59 PM
Maxicooper's Avatar
Maxicooper
Iggy,
Actually, I'm also interested in your Helix product as well. Do I need an ECU upgrade for your 15% pulley?
If not, I would like to make an appointment on next Tuesday for the pulley install.
Old Dec 10, 2006 | 09:03 PM
Alex@Helix's Avatar
Alex@Helix
you do not need an ecu upgrade for any of the pulleys, but it does help produce more power and make the car smoother.
If you want to make an apt, call the shop tomorrow. I doubt I will be in the shop this week.
Old Dec 10, 2006 | 09:11 PM
Maxicooper's Avatar
Maxicooper
With the upgraded I have on my car right now (intake, exhaust) plus Helix 15% pulley, could I achieve the goal of gaining ~25hp?
With the ECU upgraded, the term of smoother, does it mean smoother rev, smoother idle, smoother power band or etc? Kindly advise.
Old Dec 10, 2006 | 09:14 PM
Maxicooper's Avatar
Maxicooper
Oh Alex, one more question.
With the pulley only installed, does it hurt anything in the low-end? loss any power below 3k?
Old Dec 11, 2006 | 10:36 AM
Alex@Helix's Avatar
Alex@Helix
For the ecu, you will slightly get more power as well increasing driveability. It will make it smoother while you are on the throttle.
For the pulley, you should experience no power loss below 3k, in fact you should experience a power gain.
If you want to make an apt, I called the shop and they have an open spot at 10am and 3pm next Tuesday (a week from tomorrow). Just call them to confirm which time slot you want.
Old Dec 11, 2006 | 01:36 PM
Bahamabart's Avatar
Bahamabart
Originally Posted by Maxicooper
Iggy,
NO, you don't need the ecu upgrade. I have the 15 pulley and added the GIAC and loved the results. Go to Helix, drop in the pulley and take it for a spin and then have then put the GIAC on. 30 day return policy
search "giac" to read threads
Old Dec 11, 2006 | 01:37 PM
Bahamabart's Avatar
Bahamabart
smoother everything!
Old Dec 11, 2006 | 04:04 PM
Maxicooper's Avatar
Maxicooper
Thank you for the information. I will give the shop a call tomorrow.
Old Jan 8, 2007 | 05:42 PM
Maxicooper's Avatar
Maxicooper
After having 15% pulley for 5 days and almost 1k miles, I've had a lot of fun driving my MINI.
I feel a bit more pull from ~2k rpm up, much quicker off the line,..... but it seems like something is missing at the top end.
Could it be the software?
I start to think: JCW software or GIAC?
JCW or GIAC, JCW or GIAC, JCW or GIAC, JCW or GIAC....oh well.:impatient
Any input?
Thank you.
Old Jan 8, 2007 | 06:26 PM
JustJAY's Avatar
JustJAY
Any input?
Thank you.
I actually have the same problem. MM 15% Pulley, Miltek Catback, MM CAI, Unichip.
Old Jan 8, 2007 | 08:35 PM
SharoSC02's Avatar
SharoSC02
I feel excatly the same at the top end. No extra power that I like to feel and experiance. I am working with a shop at the moment to have a Head/cam with H-ignition wires, NGK spark plugs, lighter crank pulley (2006 stock) with an oil catch can installed. They are being too busy/lazy to call me back and have my order rolling with the parts and are not returning my calls. They do a very good job on Minis but are horrible in call returns and clientel follow up.
Wish I could have a shop close by that was responsive and fast.
ebowling
90
Aug 4, 2019 09:15 AM
triple5soul
21
Jul 29, 2016 04:27 AM
Getrieben
Aug 15, 2015 09:09 PM
minipopkart
Aug 13, 2015 05:22 AM
joelcseymour
Aug 7, 2015 12:43 PM
