Drivetrain Alta V2 Intercooler Installed as well as a few other goodies.
Old Dec 5, 2006 | 08:01 AM
cliff@coasttocoastusa's Avatar
Former Sponsor
Last weekend I took it upon myself to adorn the underside of my bonnet with a few new parts. In all the Alta V2 IC, LOTF engine damper, HKS SSQ BOV, and the new Alta 3" exhaust were installed.
Here are a couple pics of the new engine compartment:
Here is a crappy picture of the exhaust:
The alta IC seals very tight against the hood and instructions are well written.
The new 3" Alta exhaust as big as it is fit with no problems.
The engine damper certainly has made a noticable difference in the way the car reacts to the right foot. More things seem to be rattling now but the tradeoff is worth it.
Just thought I'd share...
-Cliff
Old Dec 5, 2006 | 08:05 AM
mdsbrain's Avatar
mdsbrain
What a weekend of upgrades
Old Dec 5, 2006 | 08:23 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Is there something tack welded to the top that holds the seal?
Old Dec 5, 2006 | 08:28 AM
Big Daddy's Avatar
Big Daddy
That IC looks real sweet! (well, so does everything else, too. )
Old Dec 5, 2006 | 08:31 AM
Former Sponsor
I wouldnt call it a tack weld but there is a small bracket that runs the length of the IC for the attachment of the seal.
-Cliff
Old Dec 5, 2006 | 08:33 AM
Former Sponsor
Thanks,
I am really impressed with the fit and finish of this unit.
Old Dec 5, 2006 | 08:34 AM
JoeCool's Avatar
JoeCool
Can you access the spark plugs with the V.2 installed? Was it simply a bolt-on, or was there any trimming involved? Very nice set up, BTW.
Old Dec 5, 2006 | 08:54 AM
Former Sponsor
Thanks,
Plugs are easily accessable now. There is some trimming neccessary to receive full benefit of the IC but the entire install should'nt take more than 2 hours.
Old Dec 5, 2006 | 09:27 AM
LordOfTheFlies's Avatar
LordOfTheFlies
Ok what I want to know is why you didn't snap a pic of your damper! Heh heh.
Old Dec 5, 2006 | 09:38 AM
Former Sponsor
Hard to see but I assure you it's there
Old Dec 5, 2006 | 09:49 AM
LordOfTheFlies
Nice! Heh heh.
saifa's Avatar
saifa
Looks nice man...that damper looks like it was a tight install though. How is the fit of the Alta exhaust? Any rattles or anything?
Seann
Old Dec 5, 2006 | 09:54 AM
Former Sponsor
The damper is definately a tight fit but there is no rubbing or problems thus far. The alta exhaust was tapping on part of the heat sheild at first, but a simple push here and there and no more rattles.
Thanks,
-Cliff
Seann
Old Dec 5, 2006 | 10:00 AM
rivet's Avatar
rivet
Looks really nice. How is the sound of the new exhaust?
Old Dec 5, 2006 | 10:10 AM
Former Sponsor
A bit deeper than the previous Borla race. It is reasonably quiet until you really get on it. I will post a video sometime soon and that will give a better representation.
-Cliff
Old Dec 5, 2006 | 10:31 AM
MINIAC's Avatar
MINIAC
What needs to be trimmed?
Old Dec 5, 2006 | 11:11 AM
Former Sponsor
It is recommended to trim the lower portion of the hood scoop for optimum air flow.
Old Dec 5, 2006 | 01:30 PM
newbs49's Avatar
newbs49
Cliff are there any fittings on the intercooler for temp gauges as in the M7 unit. Very nice looking job. Any performance difference in the exhaust.
Old Dec 5, 2006 | 01:34 PM
cartar452's Avatar
cartar452
hmm surprised nobody's asked about the new BOV...hows it sound???
Old Dec 5, 2006 | 01:52 PM
Former Sponsor
haha, it sounds like a snake hissing combined with the noise an airhose makes when you disconnect from the compressor. Thats the best way I can describe it.
Old Dec 5, 2006 | 01:55 PM
Former Sponsor
Thanks,
No fittings as it is but looks to be fairly easy to add if needed. The casting on the endtanks is very thick and solid and would be an easy location to tap. The car is much faster now and the power is instantaneous. I added many things at the same time but I'm sure alot of the change has to do with the larger flow of the 3" exhaust.
Old Dec 6, 2006 | 04:53 AM
stevecars60's Avatar
stevecars60
Cliff, looking pretty BOSS. I like it!
Any chance you could post a pic of the core? Is it a extrusion fin design?
Old Jan 21, 2007 | 05:32 PM
robino's Avatar
robino
can u show what needs to be trimmed, what area of the stock scoop when using the Alta 2.0 IC?
Helix13mini
Oct 26, 2018 05:50 PM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
